I have this problem with an old Asus laptop (asus k42J series)
The HDD is completely full. and its because of a file called tmp.tmp. and theres a random file thats running on the start-up that prevents me from using MSE or malwarebytes.
 And each time i delete that tmp file manually it comes back again.
HELP.
post-123842-0-51982700-1420462973_thumb.
post-123842-0-32068200-1420462978_thumb.
Lo and Behold
https://linustechtips.com/topic/284889-over-60gb-on-tmp-files-help/
Delete that exe file that it's pointing to, or disable the startup item, restart then delete the file and the temp file.
It's because that program is running on startup that it's adding the files back again.
Another way is finding that process, (Appdata/Roaming/init.exe?) and end it from task manager, then delete the file and delete the tmp.tmp file, then restart and it shouldn't be back. Then run ccleaner and your mse/malwarebytes.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
Run Ccleaner.
Go to Run -- > Type %temp%
Delete everything!
Run ADWCLEANER
Also disable that startup item that you rounded on that picture.
That doesn't seem to look legit to me!
this^
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
Delete everything in AppData\Local\Temp and reboot.
Run Ccleaner.
Delete everything!
Run ADWCLEANER
this^
Yeahp. I booted on a ubuntu then deleted everything you said. HAHAHA Will report back what happens
Lo and Behold
