Go SLI and 4790k or 4690 without SLI
Solved by dragoon20005,
I think I'll go that way, but is sli is really worth it? It needs bigger case, PSU and board. I'm concerned about that dual 970 will perform worse than single 1070.
the performance difference between the gen of GPUs tends to be around 10-20%
your daul 970 will last at least 2-3 years before you need to upgrade
you only concern is if your games support SLi, if not you are stuck with one GPU power
if you worry about SLi now, get the GTX980 and call it a day
wait till the next GPU comes out and decide to add another GPU or upgrade to the single next gen card
