Hi peeps,
Just thought I'd ask a rather curious question, do you have sleeved cables or regular cables in your rig?
Yep, that's about it.
I've added a poll to get an overall view, but I'd appreciate you also commenting below, please.
Cheers,
Matt (AKA Geekazoid)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/284797-sleeved-cables-or-regular-cables/
Yeah, as nice as it is it's kinda hard to justify the expensive just for a bit of coloured material covering your cables (like a jumper for your cables)?
Wheres the option for mixed? Mine is half and half.
Well, I didn't really think people would have sleeved cables mixed with regular cables, that's why that option doesn't exist.
Regular cables with sleeved extensions.
"Graphics and gameplay are not mutually exclusive."
"Nvidia, AMD, Intel, or whatever company out there has only one end goal and that is PROFIT.
If you think these companies exist for any other reason you're gonna be disappointed my dear. CAVEAT EMPTOR"
I have a semi modular psu with sleeved extensions if that counts lol
Remember a wise man once said, "You'll most likely hear/see more bad reviews from products than good, because if they get a good product, they won't bother to write a review, and if they got a bad product, they'll complain about the product" ~ SoftenButterCream
I prefer blacked out cables with just normal insulation. Sleeving frayes, gets dusty, and most have heat shrink which greatly increases the bend radius at connectors
Main Rig: http://linustechtips.com/main/topic/58641-the-i7-950s-gots-to-go-updated-104/ | CPU: Intel i7-4930K | GPU: 2x EVGA Geforce GTX Titan SC SLI| MB: EVGA X79 Dark | RAM: 16GB HyperX Beast 2400mhz | SSD: Samsung 840 Pro 256gb | HDD: 2x Western Digital Raptors 74gb | EX-H34B Hot Swap Rack | Case: Lian Li PC-D600 | Cooling: H100i | Power Supply: Corsair HX1050 |
Pfsense Build (Repurposed for plex) https://linustechtips.com/main/topic/715459-pfsense-build/
