Simple question (I think)
Go to solution Solved by Enderman,
A single cable will be enough, but if you want to do some extreme overclocking or a more power hungry card then you should use two cables for safety.
I have a Corsair RM750 power supply, and a Sapphire r9 280x.  My power supply included pci-e cables that terminate into 2 8-pin connectors.  Can I use just this one cable for both my 8-pin inputs on the GPU, or should I run another cable for better power delivery?  Thanks.
https://linustechtips.com/topic/284572-simple-question-i-think/
you mean use 1 cable from the PSU to 2x 9pin headers ? yep you can do that
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/284572-simple-question-i-think/#findComment-3863037
Yes.You can use the single cable to power up the GPU.
 C++,Assembly,Reverse Engineering,Penetration testing,Malware analysis
Do you have a question?Are you interested in programming?Do you like solving complex problems?Hit me up with a pm.
https://linustechtips.com/topic/284572-simple-question-i-think/#findComment-3863042
https://linustechtips.com/topic/284572-simple-question-i-think/#findComment-3863058
It doesn't make a difference. The rm750 uses a single 12v rail.
https://linustechtips.com/topic/284572-simple-question-i-think/#findComment-3865369
I mean for the cables, so they you dont draw 400W through a single cable since that can be a fire hazard.
https://linustechtips.com/topic/284572-simple-question-i-think/#findComment-3867899
It doesn't really matter. The 280x doesn't pull nearly that much power.
Higher quality (or non-crap) psus also don't low-ball to just to cover the official pcie cable specifications which is why you don't see systems with 295x2's exploding.
https://linustechtips.com/topic/284572-simple-question-i-think/#findComment-3868828
well psu wires are quite thin actually... usually 16 or 18awg which is way too thin imo
if you overclock a lot or use a very power hungry card, the cables could possibly become a power bottleneck
i would like to see PSUs using 14-12awg
its what rc cars with over 50 amp ESCs use...
https://linustechtips.com/topic/284572-simple-question-i-think/#findComment-3871492
