I'm building my friend a new computer and this is my first time building an AMD PC.
Budget: $1200
Please give me advice on the build. Should I stick with the Radeon R9 270 or NVIDIA GTX 750 Ti or wait for the GTX 960?: The leftover money will be spent on mechanical keyboard.
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($136.00 @ IJK)
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard  ($129.00 @ CPL Online)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($63.00 @ Centre Com)
Video Card: MSI Radeon R9 270 2GB TWIN FROZR Video Card  ($215.00 @ CPL Online)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($84.00 @ PLE Computers)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($43.00 @ Centre Com)
Total: $1089.00
Generated by PCPartPicker 2015-01-05 01:34 EST+1100
Hi
https://linustechtips.com/topic/284234-aunew-build-plan-help/
Budget: $1200
Total: $1089.00
GTX 960 will be out of the price range anyway. Can you please let your friend or you fill in this form:
1. Budget & Location
You may have listed a heap of parts that all add up to your preferred budget but it is easier if you just list the total amount you'd like to spend and the currency as well as if you'd consider going above that budget for more performance. We need the location as well because $US are different to $AUD and $CAD ect.
2. Aim
What is the system going to be used for? Web browsing, 3D work? Different systems need different levels of performance - a computer based for web browsing and office use won't handle heavy graphic design and video editing and a proper video editing system isn't good for gaming. If your aim is for gaming, please list what sort of gaming. In the same way that different usage types need different systems, you'll need a lot more power to run Far Cry 3 or Crysis 2 than you would Minecraft.
3. Monitors
How many monitors do you plan on running? Do you plan on moving to more monitors in the future? What resolution are they at too?
4. Peripherals
Do you also need to purchase peripherals such as keyboards and mice as well as monitors ect. Also please tell us if you'll need an OS such as Windows.
5. Why are you upgrading?
We ask this because you may see upgrading as the only path to solve an issue but things such as driver updates, reconfiguration or cleaning can boost performance without spending a cent.
Interested in Business and Technology
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3857693
2. Aim
3. Monitors
4. Peripherals
1. In Australia and I stated in the title :).
2. Mainly gaming
3. Only 1 and will be running at 1080p
4. We will decide our peripherals later and we don't need windows OS.
5. His computer is to out of date. Pentium 4, 2GB DDR2 and GTX 7600
Hi
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3857717
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($227.00 @ Centre Com)
Motherboard: ASRock Fatal1ty H97 Performance ATX LGA1150 Motherboard  ($125.00 @ Scorptec)
Video Card: MSI Radeon R7 260X 2GB Video Card  ($145.00 @ CPL Online)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($75.00 @ CPL Online)
Total: $985.00
Generated by PCPartPicker 2015-01-05 01:53 EST+1100
Keep the R7 260X for a while and when the 960 comes out, sell it and get the 960 ;)
"an obvious supporter of privacy"
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3857766
http://au.pcpartpicker.com/p/kcJKxr
2. Mainly gaming
CPU
69d816ca04d1c302a86170cf6915fc90.thumb.j
$274.00       $274.00 PLE Computers                               Motherboard
f8d11d1071a1631df19f27d40fc1955e.thumb.j
$170.00       $170.00 CPL Online       Memory
f9b6387edc69c97a607fbf22225b9d52.thumb.j
$88.00       $88.00 CPL Online
                          Storage
b7eb56e9964f9c496126a903e3b198d3.thumb.j
$71.00       $71.00 IJK                               Video Card
207bbafea481394da98d301f6d94cffe.thumb.j
$479.00       $479.00 CPL Online                               Case
0b43c6c8b948e48360d0c107ec8bd63a.thumb.j
$119.00       $119.00 Scorptec       Power Supply
31803da50e7ae3f2df6ad20542c966ba.thumb.j
$92.00       $92.00 IJK
Total: $1293.00
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3857858
Dont recommend the FX6300 for that budget... i5 4460 on H97 (or similar) will give you much better performance!
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3857859
2. Mainly gaming
My reccomendation.
This system must be overclocked but that's a piece of cake. There are plenty of really clear tutorials out there and Intel has built in so many safety features that it's practically impossible to brick the CPU.
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($79.00 @ PLE Computers)
Motherboard: ASRock H81M-HDS Micro ATX LGA1150 Motherboard  ($63.00 @ CPL Online)
Memory: Kingston Fury Series 8GB (2 x 4GB) DDR3-1866 Memory  ($93.50 @ Centre Com)
Storage: Intel 530 Series 120GB 2.5" Solid State Drive  ($84.00 @ Centre Com)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($519.00 @ CPL Online)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($55.00 @ PCCaseGear)
Power Supply: Corsair VS 550W ATX Power Supply  ($65.00 @ IJK)
Total: $1055.50
Generated by PCPartPicker 2015-01-05 02:23 EST+1100
For all the people that are like ''Bro that isn't even Z97 how is he able to OC the CPU'' Check out this thread;
ASRock H81M-HDS (Micro ATX): OC to 4.5 Ghz at 1.3 volts, see post #19.
http://forums.anandtech.com/showthread.php?t=2389948
This system is basically designed for maximum FPS per dollar. For a more balanced config get something else. A good option would be the system above me made by @
JoaoPRSousa
I made sure the CPU cooler and everything else fit so that there are no surprises while building haha.
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3857928
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3857933
Buy an SSD later if you NEED the storage... or... drop the 1TB storage and grab a 256GB SSD.  I tried to squeeze a GTX 970 =/.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($298.00 @ PLE Computers)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($36.00 @ CPL Online)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  ($178.00 @ CPL Online)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($102.00 @ IJK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($61.00 @ Centre Com)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  ($259.00 @ CPL Online)
Power Supply: EVGA SuperNOVA NEX750B BRONZE 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($98.00 @ CPL Online)
Total: $1116.00
Generated by PCPartPicker 2015-01-05 02:37 EST+1100
http://au.pcpartpicker.com/part/intel-internal-hard-drive-ssdsc2bw120a401
http://au.pcpartpicker.com/part/intel-internal-hard-drive-ssdsc2cw240a310
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3858010
-snip-
You can't be serious pairing the G3258 with a 970 do you?
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3858028
It is not a bad idea.  That CPU is a place holder.  The motherboard SHOULD have been a Z97 so the CPU could be upgraded later... to a "K" series.
Look:
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($119.00 @ CPL Online)
Memory: Crucial Ballistix Sport 8GB (1 x 8GB) DDR3-1600 Memory  ($99.00 @ CPL Online)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive  ($55.00 @ Centre Com)
Video Card: Asus Radeon R9 270 2GB DirectCU II Video Card  ($205.00 @ CPL Online)
Case: BitFenix Comrade ATX Mid Tower Case  ($49.00 @ PCCaseGear)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.00 @ CPL Online)
Total: $711.00
Generated by PCPartPicker 2015-01-05 03:06 EST+1100
You can game on this thing.
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3858074
This is kinda nice:
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX Video Card  ($479.00 @ CPL Online)
Power Supply: Fractal Design Integra M 544W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($84.00 @ CPL Online)
Total: $1219.00
Generated by PCPartPicker 2015-01-05 03:09 EST+1100
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3858228
-snip-
Now that's some thing I can agree on, maybe upgrading to a 270X or GTX760?
#Gadget:
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3858265
http://au.pcpartpicker.com/p/x3KwHx
CPU: Intel Core i3-4340 3.6GHz Dual-Core Processor
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard
GPU: EVGA GeForce GTX 970 4GB Superclocked ACX Video Card
RAM: Crucial 8GB (2 x 4GB) DDR3-1600 Memory
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case
PSU: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply
Total cost: $1181.00
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3858308
These are the best build so far
Total: $985.00
Total: $1116.00
It'd be better to have a wireless adapter but it's not going to be over budget with this build :).
My reccomendation.
Total: $1055.50
JoaoPRSousa
I did suggest him to use the Pentium G3258 but he doesn't want overclocking.
Thanks folks for helping me :)
Hi
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3863340
Budget: $1200
Total: $1089.00
You should go with intel with that budget.......i'll make a better build in a bit
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/284234-aunew-build-plan-help/#findComment-3863368
