Have you tried completely reinstalling the graphics driver?
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/284204-low-fps-gtx970/#findComment-3857345
Does the game have better FPs if you turn all the settings right down to minimum graphics options?
If so, then graphics card issue, if not, something else is causing the issue. (Might just be coincidence it's showing up now)
Cartman - AMD Phenom II x6 1055T 3.1Ghz - 10GB Ram (Mwahahah) - 256GB Crucial MX100 Boot - 2TB WD Red - Gainward GTX 770 - Zalman Insanely Loud CNPS14X - Corsair 230T Orange
Stan - Intel Pentium G3320 - 8GB Ram - 128GB Intel 520 - Raid 1 6TB WD Reds - Bit Fenix Prodigy
Kenny - HP 14 Ultrabook (No name apperently) i3 4130 - 128GB Intel 520
https://linustechtips.com/topic/284204-low-fps-gtx970/#findComment-3857602
When I turn the settings all the way down the fps goes way up.
https://linustechtips.com/topic/284204-low-fps-gtx970/#findComment-3858479
Do you have any other graphically intensive games you could try? Perhaps the Heaven benchmark?
https://linustechtips.com/topic/284204-low-fps-gtx970/#findComment-3858725
I experienced a problem with my Asus strix 970 with very very poor performance in Battlefield. I found that it may be MSI Afterburner (the Rivatuner stuff). It caused an issue one way or another, and I closed out of it and it fixed the poor performance. What was happening for me was that the GPU utilization would go from 80's and 90's all the way down to 7% ish.
https://linustechtips.com/topic/284204-low-fps-gtx970/#findComment-3859273
Oh you said it stays at 100% usage....still maybe if you have MSI Afterburner in use, might be the problem....not sure though :/
https://linustechtips.com/topic/284204-low-fps-gtx970/#findComment-3859283
