Over the last few days my custom PC has started spontaneously cutting out and restarting while gaming.
The power supply is a fractal design newton r2 800 watt so it should have more than enough power. I've had it for 3 years.
Also
Theres no cooling issues with the CPU
I can provide any other details if needed
Thanks in advance.
https://linustechtips.com/topic/283600-pc-randomly-cuts-out/
Make sure your ram is fully seated into each slot. It takes a lot of pushing.
https://linustechtips.com/topic/283600-pc-randomly-cuts-out/#findComment-3849435
Also
Thanks in advance.
If it's only while gaming and the CPU temps are perfectly fine then I suspect the GPU and would RMA it.
If you can, test it in another computer and see if it does the same thing.
https://linustechtips.com/topic/283600-pc-randomly-cuts-out/#findComment-3849436
