Best wireless headset/headphones
Solved by Mao_Zedong,
Do u think those are good or shouldi get the closed ones???
It depends on what you plan to do. The closed model will have slightly more bass, but the open ones will have a much better soundstage, generally sound slightly better, and will keep your ears cooler. If there will be a lot of background noise, closed ones will cancel out the sound, but open ones won't. Personally I would get the open ones for home use, especially for gaming.
