Will upgrade become bottlenecked?
Go to solution Solved by Fate,
Yes it will bottleneck two 280x's in many games. The cheapest CPU that won't bottleneck them would be a locked i5 (something like a i5-4460).
Probably not worth the upgrade for 1080p.
Hi guys and gals, I want to upgrade my pc with a new GPU a 280x to be precise. But I'm afraid I might bottelneck the the two gpu's, so I've come her to ask for your opinion and if you think it's worth to upgrade.
My specs are:
Mobo: Asus Crosshair IV Formula
CPU: AMD 1090t
GPU: Gigabyte Radeon 7970
RAM: Crucial Ballistix Elite 16gb 1866Mhz
PSU: Corsair HX 1000w
Oc speeds: Cpu @ 4Ghz, Northbrige @ 3200Mhz, the ram is runned at a little lower speed than usual @ 1774Mhz
Cpu: Intel i7 6700k Mobo: ASUS Maximus VIII Formula Ram: G.Skill RipjawsV 3200Mhz C14 16Gb Gpu: Gigabyte 980ti Case: Phanteks Enthoo EVOLV ATX Psu: EVGA SuperNOVA 850w G2
https://linustechtips.com/topic/283474-will-upgrade-become-bottlenecked/
I wouldn't call that an upgrade, a 280x IS a 7970...
Rig: I5-3570K@4.3Ghz - Cooler Thermaltake Frio Advanced - Ram Kingston 1333Mhz 8gb (2x4) - GPU GTX 970 4GD5T OC - Motherboard Z77MA-G45 - PSU CoolerMaster GX II 750w - Storage WD 500gb HDD - Sound Edifier M3700 5.1 - Headset Corsair Vengeance 1500 - Mouse Razer Deathadder 2013 - Keyboard Razer Anansi - Mousepad Steelseries QcK+ - Xbox 360 Wireless Controller x2
RIP in pepperonis m8s
I believe he means Crossfiring, and it would bottleneck.
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
^This. Do you actually NEED an upgrade, or is it a "just cuz i can" type of boost? I think you are fine with your specs.
Wait up a bit, and get a CPU upgrade to the new Broadwell / Skylake CPUs. Then, upgrade the GPU to the AMD 300 series a bit later.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Plan to run it in crossfire with the 7970 -_-
Okay, stupid comment removed.
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
Oh, i understood by "new gpu" like it was a single gpu upgrade, then yeah, inminent bottleneck.
I'm pretty sure when he says "a new gpu" he means an upgrade of single gpus, not a 2nd one.
Crossfire will bottleneck, a 280x is just the same thing..
Read the OP... " But I'm afraid I might bottelneck the the two gpu's,"
Yep, i saw it now.
Isn't a 7970 the same as a 280x?
Yep, that's why you can crossfire it.
Ok, thanks for the help guys. Then I'll wait and just upgrade my entire system later. Maybe I'll try Intel for my next build :)
Your CPU is already bottelnecking the single 280X (7970)
Nah, a phenom ii X6 1090t is pretty cool with that, and WAY better than a FX actually, now two of them... then yeah.
Are you sure about that? I got a Phenom II 940 BE and that thing cant even drive a GTX 580 to its full potential.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
Hey guys how much would my cpu actually bottleneck a crossfire setup? Because what I could do is to buy the FX 8350.
8350 would bottleneck two 280x's in most games as well.
You need at least a locked i5 to prevent a bottleneck with those two GPU's.
Well that sucks -_-
