You already made a post about this, you don't need to make more.
http://linustechtips.com/main/topic/283241-help-with-form-factor-pc/
https://linustechtips.com/topic/283250-intel-nuc-help/#findComment-3844786
Speaking of a second post, might as well post my respond here too.
"You want to MAKE an Intel nuc ? Bruuhhh, you might as well just buy one. It's not possible to make a PC that small yet.... Although, you can buy a Gigabyte Brix, but they have overheating issues, depending on what model you buy. You can buy a cubic case like the 250D, that's probably as small as you can get attempting to "make" and Intel NUC."
"Audiophilia... when you start to hear voices in your head."
https://linustechtips.com/topic/283250-intel-nuc-help/#findComment-3844909
Guest
