Sooooooo I have a DXG 5.1 Audio card but... my integrated sound card has better audio quality and allows 192kHz 24 Bit. Where as the sound card does not..   Are sound cards even worth it lol..
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/281925-audio-card/
just because it outputs higher khz and bitrate sound it doesnt mean its better.
https://linustechtips.com/topic/281925-audio-card/#findComment-3828060
Sounds cards used to have a place on the market, they do not anymore however.
Most (95% of motherboards) have adequate audio, and if you ever actually need a sound card, a amplifier is instantly a better option.
| Intel i7 5820K @ 4.8GHz | G.Skill Ripjaws 4X4GB | X99 PRO | HoF 980 | Asus MX299Q | Sennheiser HD600 |
https://linustechtips.com/topic/281925-audio-card/#findComment-3828066
Yes it does...  im a Audiofile... the difference from 96kHz to 192kHz is so much better, i can feel the sound much better. And my intergrated audio has better bass control due to the frequencies supported by the intergrated chip
https://linustechtips.com/topic/281925-audio-card/#findComment-3828156
Wow.....how did you even got hold of 192kHz musics?
https://linustechtips.com/topic/281925-audio-card/#findComment-3828287
In the same way this train wreck got started, force of will.
Mind over matter? (or in this case, mind over 0 and 1)
https://linustechtips.com/topic/281925-audio-card/#findComment-3828309
Spotify premium supports up to it and online... but in general the Audio soounds better when i Select 192khz then the like 48/96khz option on the sound card or on the intergrated
https://linustechtips.com/topic/281925-audio-card/#findComment-3828312
Sooooo......upsampled??
https://linustechtips.com/topic/281925-audio-card/#findComment-3828323
unsampled what?
The music not being a sample 192khz? or what  u mean lol
https://linustechtips.com/topic/281925-audio-card/#findComment-3828351
Welcome to the wonderful world of placebo.
Have someone else selecting the bitrate and see if you can hear the difference without knowing what it is first.
Now thats not how these top notch audiopeeling peel, get let the placebo enter the body and fill your holes.
unsampled what?
Can be pretty sure it is, because no studio outputs that high when its pointless anyway.
https://linustechtips.com/topic/281925-audio-card/#findComment-3828353
Now thats not how these top notch audiopeeling peel, get let the placebo enter the body and fill you holes.
.... I spent hour listening to music, the same music, over and over to figure out what was different at different parts of the song and at different pitches and tones... I know it is much better.
https://linustechtips.com/topic/281925-audio-card/#findComment-3828370
... Yes... I listend to the audio eyes closed to make sure i could feel all the sound
Ok, if you really can, that's cool. I can't at al. But did you do a BLIND test?
https://linustechtips.com/topic/281925-audio-card/#findComment-3828386
Train your self :)
Superhuman hearing and sight, I hope for the day when I audiopeel hard enough to see sound.
https://linustechtips.com/topic/281925-audio-card/#findComment-3828447
