Current specs-
I3 540 @ 3.07Ghz [2 cores,hyperthreading]
4GB ram 1300 Mhz
NVIDIA Geforce 8400 GS
Intel DH55J motherboard !
500W power supply !
I know these are pretty OLD :P
I use PC mostly for Video editing [moderate]
So what should I upgrade first (i mean which part) ?
Budget aroud 250$ or less [will upgrade again after 2-3 months]
https://linustechtips.com/topic/281854-what-should-i-upgrade-first/
What's your power supply?
I think the real question is how much you plan to spend total over all the upgrades.
I need more information on your power supply. There's so much to upgrade. The first thing I would upgrade is your graphics card to maybe a 270X.
if you don`t play games than upgrade cpu first.and add some ram later http://pcpartpicker.com/p/KxfVD3 .or you could buy a used i7 860 for your motherboard
if you play games more then get a gpu. r9 270/280 and a new psu. the i3 is still capable for gaming
Edited by s3ns3
If you have a $250 budget, getting a R9 280 and dealing with the Bottle-necking till you can get a decent board and a better CPU.
| Intel i7 5820K @ 4.8GHz | G.Skill Ripjaws 4X4GB | X99 PRO | HoF 980 | Asus MX299Q | Sennheiser HD600 |
GPU first. Then the powersupply. If you get PSU first, you'll be limited to gpu.
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
