Hello , I have recently done a custom pc and I have been tryingsince yesterday to install it ... I have spend aproximately 10 hours trying to install it ....
To be honest I think my CD or USB has a problem simply because I am not able to install it ....
So I go to cmd I do all the commands I copy it to the USB , I select the USB Drive and the after choosing language and where to install windows , My computer can't accept my usb simply because the usb doesnt have the file to start downloading...
https://linustechtips.com/topic/281295-please-help-im-desperate/
Inb4 against CoC
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3819189
Can't you try installing it from the DVD?
Since you have an optical driver, it shouldn't be much of a problem to install it into your new computer.
I can't tell you how to crack Windows, since it would be against the Coc.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3819198
I think you should use a program like 'Wintoflash' to put the files on your USB drive so your new pc will accept it.
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3819203
I dont have an optical drive firend , I only have is an old laptop and my pc
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3819258
How are you getting the files from a disk then?
To be honest I think my CD or USB has a problem simply because I am not able to install it .... I trying pirating it but even soo I wasn't able too...simply because I don't usually do it
If the optical drive is in laptop, it's of course harder to disconnect, but it's not impossible.
If you think that the Windows DVD is at fault, then download the .ISO from microsoft. http://www.techverse.net/download-windows-7-iso-x86-x64-microsofts-official-servers/
Just make sure that the version you download corrospond with your licens key.
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3819281
I mean , i have one im my laptop! , sorry im tired
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3819367
No need to feel sorry, I just want to have everything in the clear.
I would suggest downloading an .ISO, since that would eliminate the disk as the culprit.
You can then use one of the programs (Rufus or WinToFlash) to create the bootable USB.
Also, in the BIOS of your new computer, try setting the USB mode to ´Legacy´ sometimes that can solve the problem of unbootable disks.
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3819417
so I can simply  do the iso thingy , put a rufus in my pen and change the usb mode to legacy?
also do I need to use the cmd?
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3821111
You don't necessarily need to put your USB controller in legacy mode. You need to do it, if there is a problem with findning the USB boot device.
You don't put Rufus on you USB driver. You use it to burn the Windows 7 .iso unto a USB driver, and it makes the USb bootable at the same time.
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3821133
wait I just used powerISO to extract the Cd to the USB... and there are some rufus files in the usb drive...soo what should I do? sorry , first time installing windows from usb
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3821474
OK; It has been some time since I have used Rufus, so I don't know what files it put on you USB.
But you need to format the USB drive, and then use Rufus to burn the downloaded .ISO to the USB drive.
Since you were worried about the state of the DVD, then I thought it was an idea to circumvent the DVD entirely.
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3821513
SO it recognized as a bootable device!!!! but there was still a problem :( I choose language  accepted the terms but the there is a part where you choose where its installed... I choose my SSD putted as primary but It doesn't work :( sorry for bothering you
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3829182
You aren't bothering me at all.
Does the SSD have something already installed in it. If yes, then you should format it before installing Windows on it.
If no, then you need to format it. If I remember correctly you need to click ´New´ when the SSD is selected.
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3829291
the problem is not the SSD , the problem is  that I can choose the SSD but then when I have to select the pen that has the files to install  , I can't
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3829482
If you can boot from the USB, and chose language and accept the ToS, then the USB drive should be working.
Could you maybe take a picture of the screen you are stuck on? it has been a while since I did a Windows install, so that would help a lot.
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3829643
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3830332
ok
http://imgur.com/NFtHf92,zQSE9xt,MtwheNI#0
 click next , there are 2 more
Hmm, are you running a RAID setup?
I don't speak a word of Portuguese, so it is a bit hard to tell what is on the screen (I don't know why I didn't think of that), but I look like you are loading a RAID driver, rather than installing Windows.
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3830410
raid driver?
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3830425
raid driver?
If you are running a a RAID setup on the onboard controller, you need to install a driver for the onboard SATA controller for it to work probably. But if you aren't running RAID, just discard what I said.
Could you tell me what the ticked off box in the back of this picture says.
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3830469
It says select the controller to be installed
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3830563
Untick that box. You aren't trying to install a controller.
It want a driver, but as mentioned, if you aren't running RAID, you don't need to install that yet.
https://linustechtips.com/topic/281295-please-help-im-desperate/#findComment-3830582
