CPU overheating troubles
Go to solution Solved by legendnb,
its a laptop so its kinda hard to replace a cooler
how long have it been since you did some maintenance work?
either bring to a laptop fixing service, or you can do yourself,
  1. remove the back panel of the laptop to access the cpu,
  2. remove the heat sink, and clean off the thermal paste off the heatsink and chip,
  3. clean the heat sink fan/ all the fans
  4. reapply the thermal paste
  5. put everything back
oh haha should´ve thought about that. sry
activate vsync and go over the air intakes and exhaust with a vacuum cleaner.
Maybe you need to replace the thermal paste, but I´m the wrong person to ask for how to go on with this.
https://linustechtips.com/topic/281173-cpu-overheating-troubles/#findComment-3817595
Hey.
My laptops AMD Phenom II N970 quad core CPU reaches 100.1 degrees Celsius just play playing minecraft and being in a skype call. I don't even know whether it is over clocked or not.
It's a laptop afterall. Time to use the /r/buildapc catch phrase "BUILD A PC".
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/281173-cpu-overheating-troubles/#findComment-3817632
Isn't the TJ Max around 65C?
https://linustechtips.com/topic/281173-cpu-overheating-troubles/#findComment-3817665
Case: Corsair Carbide 540 Air, CPU/MOBO : I5-4690K @4.4GHz (stable) on Kraken x61 AIO Cooler, MSI Gaming 9 AC, Ram : Corsair Vengeance 2x8GB 1866, GPU : AMD R9-290 4GB Ref with G10 Kraken Bracket and x61 AIO Cooler, Storage : 2x Samsung 168GB SSD in Raid 0, 1x WD 4TB Black HDD, PSU : Seasonic Platinum 1200W
https://imageshack.com/i/exwScEj7j
Keyboard : Razer BlackWidow Ultimate, Mouse : Razer Ouroboros, M/Pad : Razer Goliathus Control (Extended), Sound : Astro A40 Headset W/ MixAmp Pro / Harman Kardon 2.1 Soundstick III
https://linustechtips.com/topic/281173-cpu-overheating-troubles/#findComment-3817693
whats TJ max
maximum temp the cpu gets to untill it shuts off
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
https://linustechtips.com/topic/281173-cpu-overheating-troubles/#findComment-3817694
i had an AMD  turion laptop, tj max was 126 degrees :0
https://linustechtips.com/topic/281173-cpu-overheating-troubles/#findComment-3817697
Laptops are designed that way.
But I don´t like the idea that I can boil water with them ~.~
Laptops are not designed to run at 100C.
https://linustechtips.com/topic/281173-cpu-overheating-troubles/#findComment-3817725
Some people might not have loads of  money to spend on a pc. Just because i dont have a pc doesnt mean that you need to patronise me.
you can actually get a pc capable of running mincraft at comfterable fps and resolution for as little as 350$-400$
to get back to the issue, if you feel the laptop itself, does it feel really hot? it might just be the temp reader that somehow broke... if it is actually getting this hot, i'd advice you to replace the thermal paste, either by opening it yourself and cleaning the existing off with a cloth drenched in alcohol and applying a small dot of high quality thermal compound, or by taking it to a local hardware repair shop (though not all shops will do this for you..)
https://linustechtips.com/topic/281173-cpu-overheating-troubles/#findComment-3817752
i dont just play minecraft i play other games as well
https://linustechtips.com/topic/281173-cpu-overheating-troubles/#findComment-3817766
