My brother's computer had this problem, while he was playing WoW his computer suddenly hung and when he restarted it the computer starts up and shuts off in an endless cycle (nothing appears on the screen)
I tried resetting CMOS/ swapping the battery out but it doesnt seem to work.
Both GPU and CPU fan moved (when it starts up) and stops when it shuts off.
All of the light on the MOBO shuts off when the computer shuts off too!
HALP D:
His Computer specs
Some I5 CPU
h67MA-E45
gtx 460 MSI
Edited by xnoobftw
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/281143-help/
idk why and i don´t know how it´ll fix your problem.
But disconnect the hdd (sata and power for the hdd) and try again.
y not :-c
Tried it... Didnt work :( Thanks anyways! :)
https://linustechtips.com/topic/281143-help/#findComment-3817189
Did you try turning off and on?
No but like seriously, maybe the psu went bad or the mobo or cpu is failing .
Multiple times!
Still no luck D:
https://linustechtips.com/topic/281143-help/#findComment-3817191
hmm, I would disconnect and shutdown the psu for a few hours and then test again.
Turns out the PSU was faulty :)
(I gave him my old one for a new year present)
Happy new year and thanks! :D
https://linustechtips.com/topic/281143-help/#findComment-3817433
