Is the newer CM Hyper D92 better than CM Hyper EVO 212?
Solved by WoodenMarker,
Welp mixed results, I'm lost now lol. Rifle bearing is supposed to last longer than Sleeve so based on that D92! But Evo 212 performs better in the other results... Idk what do you suggest?
The 212 Evo is hard to go wrong with. The noise factor is something that would deter me from the D92.
Replace the 212 Evo stock fan with a Hyperborea, profit
Rifle bearing is just "enhanced" sleeve bearing. The only big benefit is that allows the fan to be used horizontally without it wearing out a lot quicker then vertically like sleeve bearing fans do.
Could probably just get a better cooler in that case.
