Hello Linustechtips,
I like to make and maintain my systems my systems the best way, so cleaning is one of the maintenance points. Cleaning the dust in these systems is no problem, but thermal compound and other dirt on surfaces(except the pcb's) are a point which I am uncertain about. Since I follow the YouTube channels quite a lot I know LinusTechTips always promote isopropyl alcohol, but since I don't know where to buy it in my country, I'm searching for a substitute. I also work in a car workshop, so I have some cleaning supplies. We also do repainting and the cars need to be completely clean without any residue. We use a product which is freely translated "silicone degreaser". Do you think this product will be a proper cleaning liquid for previous stated parts? Won't it damage my cpu's and other hardware? I'm looking forward to the reply.
P.s. sorry if my English is bad cause it is not my native language
https://linustechtips.com/topic/280844-cpu-cleaning/
I actually haven't thought of it yet, but you can use even something like vodka. :lol:  I even googled it, and there were actually some ppl using it. Not that I recommend it, but it seems to work.
I guess even nail polish remover could work. Not sure about that, but I've just seen that some of them also consist out of alcohol. But don't quote me on that :P
https://linustechtips.com/topic/280844-cpu-cleaning/#findComment-3813341
You could try your local pharmacy, isopropyl alcohol is also used to clean wounds :)
NingoCase: NZXT H440 White, Motherboard: MSI MPower Z97, CPU: Intel 4790k, Cooler: Corsair H100i (2x Noctua NF-F12) GPU: MSI GTX 970, Memory: 12GB Kingston, SSD: Samsung EVO 120gb, HDD: Seagate Barracuda 2TB, PSU: evga 850 g3
https://linustechtips.com/topic/280844-cpu-cleaning/#findComment-3813373
