That's probably not right.  The fan blows air into the heatsink and I'm assuming you want the air to be blown out the back of the case.
i5 4670k (can OC to 4.4Ghz) - Hyper 212 evo w/ AC MX2 - XFX Radeon R9 280X8GB ADATA XPG V2 DDR3-1600 - MSI Z87 G41 - Corsair CX600M 600W PSU - 1TB HDD - 120GB SSD
https://linustechtips.com/topic/280551-hyper-212-evo-question/#findComment-3809262
If you have the fan blowing air towards it, then it's fine. Otherwise, just take the fan off the actual heatsink and move it to the other side.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/280551-hyper-212-evo-question/#findComment-3809316
Ah, will I need thermal paste remover etc. to change its direction?
No, just take off the fan and put it on the other side.
https://linustechtips.com/topic/280551-hyper-212-evo-question/#findComment-3809322
Would doing this not make it a pull fan? or does it not work like that?
There is an arrow on the fan you can flip it anyway you want. You can make it push or pull.
https://linustechtips.com/topic/280551-hyper-212-evo-question/#findComment-3809541
