Havent done anything to my PC. now  idle to low load temps are between the mid 20s to mid 30s when OCed to 4.2Ghz. My room feels cooler, could this be why?
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/280421-why-did-my-cpu-idle-temps-decrease/
load temps at 30s?? that is either extremely good or something is extremely wrong?
Try different programs to measure temps....
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
When you push air across a radiator that air is your rooms temp air so what ever your room temp is the lowest your components temps can go. so if you live in a hot area with no aircon your temps will be higher vs living in alaska with aircon
GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 @1500mhz + 8000Mhz CPU: Intel Core i7 6700k Delided and Overclocked @4.8  MB: ASUS MAXIMUS VIII IMPACT  RAM: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory CPU Cooler: Corsair HG10+ H90 +H90 CASE: Corsair 380T  Storage: 120GB Samsung Evo SSD + Crucail 256GB Mx100 + 2TB Seagate/  OS: Windows 10 64bit Power supply:  Corsair RM750
Reread the post.
low load temps. e.g, youtube, when CPU is at 10-15% usage
Reread the post.
I doubt that if the room is a little bit cooler it means the the load temps goes down by 30 to 50 celcius cooler....
I live in the UK and it snowed a couple of days ago
Aha I thought that when you are stresstesting:D
But then it is normal. at 10-15% usage around 20-30s is nice
Low load, temps went down upto 10 degrees
