Ok so i use pcpart picker to pick my parts and it has a compatibilty thing.
and this is what i have so far     http://au.pcpartpicker.com/p/KjPHbv
Nothing wrong other than the ssd but im not going to buy it im just doing a worst case scenario.
it ssays the cpu cooler will  fit
than i check corsairs site and it says the 120mm is most and the 412 slim is 132.. on review sites its sasy 130 is max. ,idk anyone have any experience or can find out. ik tried calling corsair but yea didnt work ou no answer.
Do not take life too seriously. You will never get out of it alive.
        :o
https://linustechtips.com/topic/280288-will-this-cpu-cooler-fit/
For such a wide case, the Air 240 is disappointing in its CPU clearance. For reference, my cooler is 165mm and it wouldn't fit in the thing and that's a shade taller than the famous Hyper 212+. Checked the site and it does list 120mm as maximum height which isn't all that impressive give this case is considerably wider than many cases that can support coolers 170mm+. That cooler you listed is 132 x 106 x 160mm.
Why not get a Phanteks Evolv instead? Better build materials, crazy water cooling support and way more clearance for CPU coolers. Or if you want a cube, the Thermaltake Core V21 also has better cooling support as well.
https://linustechtips.com/topic/280288-will-this-cpu-cooler-fit/#findComment-3805730
i want small compact case. was looking into 380t and this was around the same size so i chose this. so it wouldnt fit at all... Cmon that sucks. @Mooshi
        :o
https://linustechtips.com/topic/280288-will-this-cpu-cooler-fit/#findComment-3805873
Check out the Core V21 then. It's a compact cube with tons of cooling support.
https://linustechtips.com/topic/280288-will-this-cpu-cooler-fit/#findComment-3806009
will do.. its just that i dont really like thermaltake. when i did my first built i orderd 1 part from them and it wass the first ti arrie and it was dead and yeah. stayed away from them but will check itoputt. asrjfkaleh;alkejfklajef/ajw'[fphnat;f
        :o
https://linustechtips.com/topic/280288-will-this-cpu-cooler-fit/#findComment-3806020
If you're in love with the Corsair case, you could always get one of those coolers that is flat/compact with a 140mm fan on top or a high end cooler that uses 92mm fans, Noctua makes good mini coolers.
https://linustechtips.com/topic/280288-will-this-cpu-cooler-fit/#findComment-3806042
Will see.  they dont sell the thermaltake case in aus. or i cant dfind it.
        :o
https://linustechtips.com/topic/280288-will-this-cpu-cooler-fit/#findComment-3806903
