Ok, titan update.
I hated the green led.
It doesn't match my build theme so why not just paint it red.
Ok the bad news that I have is that I broke the cover of the side.
If you can see closely, you would notice it have broken off and left like half of it.
I don't mind because it's gonna be a dark red build so you can barely see it at the end of the build.
And if you see the second picture, you can see that some paint marks on the left.
Note to self, never touch paint and be patient when drying.
So, I decided to use a scotchbrite 3m pad to scuff up the surface to give a brush aluminium look.
To me, it looks beautiful and I frosted the acrylic.
At the end, I'm quite satisfy with the result.
Next update would be the window.
Enjoy the pictures now.
And YES, It still works.
Last picture shows it running.
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-433192
Just a mini update.
IT IS MADE OUT OF BRASS.
Though abit offtopic,
It's gonna be use to measure my case.
I'm gonna use it in something you would not expect.
Signed by the one and only Bill Owen.
Thanks Bill if you are reading it.
This ruler is one of two Bill has ever build. (he claims)
Stay tune and enjoy the pictures.
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-440066
Well, I have bad news and good news.
First is that I broke my tj08e case
You will be like "Jake, how you broke your case?"
I will be like "I cut a window that is near the edge where the support of case is blocking the acrylic.
So I can't fit it.
So I change case.
But surprisingly, it's always Corsair who comes and saves the day.
Not a big fan of Corsair but I always need to rely on them for fast replacements.
Not gonna mod it because I'm tired and I'm just not in the mood.
Enjoy the teaser.
Guess the Case if you want.
Next update will be the final pictures.
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-453930
OK, time to end this project.
It's been hell of a bumpy ride and let's end it here.
First of all, it's a 350D.
What a expected surprise.
I finally got all working and I'm currently using it right now to type this final update (hopefully).
Unfortunately, I can't show you the cable management and I hid the SSD at the back.
Anyway, I want to thank everybody who supported me through the build and I wish I can do more.
Sad news is that I'm putting my amateur modding abilities to a rest as I will be focusing on studying overseas.
Hence why I built this system anyway, without further ado.
Enjoy the pictures.
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-467442
wow, love the sleeving! is that MDPC? looks thiner...
awesome clean build,
did you use plasti-dip to paint the "GEFORCE GTX" logo?
is a local brand. but I do suggest getting paracord if you are doing it for the first time since it's way cheaper than mdpc.
I use spray paint at first, so at the end, I just sharpie and just colour it in. But I do highly suggest plasti-dip if you can find it, it makes spray painting a whole lot easier.
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-469269
Thanks for the tips!
looks great :)
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-469502
very nice! that cpu cooler is huge :)
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-470128
"Air" like the anime made by Key?
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-472645
Really nice build
Intel 3570K - MSI GTX 660Ti 3GB OC Edition - 16GB Corsair LP RAM - ASRock Extreme4 Motherboard - Corsair HX850 - Adata Premier Pro SP900 120GB SSD with Windows 7 - Seagate Barracuda 1TD HDD - Seagate Barracuda 500GB HDD - Thermaltake Frio CPU Cooler - CM Storm Enforcer Case - Macbook Pro Early 2011 Laptop
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-472697
I really admire you just 17 and you can build an ultimate gaming pc.
Where can I get those sleeved cable ? price ?
U just need $$, pple will admire straight away regardless.
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-477744
Can't agree more.
Build was more interesting with TJ08-E, 350D doesn't have that 'thing'.
I like painted RAM sticks, but for me, you just messed up GPU with that paint and broken thing.
Anyway overall it's a nice build.
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-478651
Can't agree more.
Yea. I need to agree on everything on what you say.
I really do enjoy tj08-e. has more modding potential.
The 350D is just like a box with a default layout.
And I wish I shouldn't have broken the GPU.
https://linustechtips.com/topic/27986-project-air/page/3/#findComment-478693
