Sorry guys I didn't have the time for a full build log, but I just wanted to show you the finished product. So my friend has finally decided to get into pc gaming with me and ditched his xbox. He spent way more than I would have on his first rig but he's glad he did. This was my second build, and as you can tell from you first picture(my rig, first build), I have discovered cable management. Soon enough, those optical drive cages will be removed and the rig will be fitted with some awesome watercooling. 360*60 up top and 280*80 up front, haven't planned out the rest just yet.. The 212 evo is just a temporary placeholder.
Components:
FD Arc Midi R2
MSI Z87-GD65 Gaming
4770k (stock speeds for now)
EVGA gtx780 (stock speeds for now)
G.skill Ripjaws 2133 cas 9 ram 16gb
Samsung 840pro 128gb
Seasonic 650 watt psu
I'm pretty sure that's it.
post-12620-0-94469800-1371732212_thumb.j
CPU: Intel i7-3770k at 4.8Ghz  CPU Cooling: 320mm UT60  Motherboard: MSI Z77A-GD55  RAM: G.Skill Ripjaws X Series 16GB 2133Mhz (2x8GB)  SSD: Intel 330 Series 120GB  HDD: WD 1TB Caviar Green  GPU: EVGA GTX 780 x2  Sound Card: Creative Recon3D  PSU: Raidmax RX-1000AE 1000W  Case: Arc Midi R2  Monitor: Benq XL2420T at 129Hz  OS: W8 64Bit  Keyboard: Razer Blackwidow 2013 Ultimate  Mouse: Logitech MX518  Mousepad: Steelseries QCK+  Headset: Turtlebeach X12 (Temp.)
https://linustechtips.com/topic/27978-build-for-a-friend/
extremely nice cable management in his build,can't wait for updates.
gotta love the Fractal design cases.
@Artem
I do agree that he spent more than he should have though.
-16GB ram
 -high frequency
 -low latency
-i7 for gaming
all the parts bought are great quality,but I think the ones I listed are a bit excessive for gaming purposes,though should he ever want to try video editing or streaming he'll have hardware more than capable of it?
also is there an HDD at all?because 128GB is awfully small.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355608
Thanks, ill keep you guys posted:)
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355617
Ya I will be getting the same case as well. Love the watercooling capabilities it comes with. Rad options being one of the biggest.
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355624
He works as a mechanical designer/drafter, he got the cpu and ram so it could speed up solidworks and keyshot 3d model renders, but its primarily for gaming. Is high frequency ram and low latency a bad combo?
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355636
@Artem
-16GB ram
 -high frequency
 -low latency
-i7 for gaming
No I removed all cages because 128gb is fine for him (at least he thinks so), and it was necessary for the future rads. He uses an external drive for all his media.
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355658
Looks extremely nice your friend is extremely lucky to have a extremely good builder like you :D
Thank you  :blush:
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355692
BTW, I am blown away at how much his 780 blows my 680 out of the water, frame rates are comparable to 680 sli frame rates in bf3! Anyone interested in a 680?  :P
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355704
no,high frequency and low latency are ideal for 3d modeling/animation and video editing.
but for gaming anything better than 1600mhz CL10 is more or less a waste of money.
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355708
isn't there 2 spaces for 2.5" drives in the back?you could buy a 2.5" 500GB HDD.
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355713
Ill keep that in mind, thanks!
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355719
Yes there is room for one more, but he uses an external for media and other things, so he should be fine with a 128gb ssd:)
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355723
lol I understand that but the reads and writes on external drives tend to be significantly lower than internal drives.just something to consider.
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355742
He cant tell the difference :lol:
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355746
that is pretty neat
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-355753
I'll give you my soul :P
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-358291
Looks very nice and tidy. Was there any particular reason he decided to go with air cooling for the CPU? Just to save a bit on the overall cost or was he not too interested in a high overclock?
Explanation:)
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-363359
he can't tell the difference? mind if i steal his SSD and replace it with a hdd? he prob can't tell the difference if he cant tell the difference between ssd and EXT hdd.
msi h77ma g43
i5 3470
Coolermaster hyper 212 evo push+pull
Powercolor 7950 pcs+ @1100 mhz core 1400mhz mem
Coolermaster haf 912 advanced 120mm rear, 200mm top 200mm front
Corsair vengeance 2x4gb 1600 MHZ
Windows 8 64bit
Silverstone essentials 500w ST50F-ES
Samsung dvd drive
2x 250GB Hitachi RAID0
Seagate Barracuda 2tb
LG IPS235p
Razer Blackwidow
Razer Deathadder
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-366590
It would probably take him a while to figure it out:)
https://linustechtips.com/topic/27978-build-for-a-friend/#findComment-370370
