HI, I'm not sure why but I just got an Asus 280x and when I installed it my system wouldn't get past the Bios and would just, I have a LGA 1156 I7 and 12gbs of ram running windows 7 and a 4870 in the system right now and runs fine like this, PLease help, I would love to get this card working for me
https://linustechtips.com/topic/279639-r9-280x-crashes-pc-help/
before you install the GPU
did you install the AMD drivers?
what GPU were you using before the 280X?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/279639-r9-280x-crashes-pc-help/#findComment-3796159
Okay, install the old card back and see if the system boots up fine. It might be a problem with the 280X.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/279639-r9-280x-crashes-pc-help/#findComment-3805439
I uninstalled my Radeon HD4870 Drivers and didn't install the new one's in yet
yea it may be a good idea to install the latest drivers before you install the new GPU
https://linustechtips.com/topic/279639-r9-280x-crashes-pc-help/#findComment-3805440
it boots fine with the 4870 but this is the second card I have tried that would freeze when booting and would freeze in my bios, I read somewhere that it could be my bios drive is out of date or my PCIe 16x wont actually support it,
https://linustechtips.com/topic/279639-r9-280x-crashes-pc-help/#findComment-3813434
So today I was able to finally try my GPu on a different computer and I found out that it is just my motherboard that isn't compatible with the GPU, but thanks for all the help.
check if your mobo has any BIOS update
maybe the BIOS do not identify your new GPU
https://linustechtips.com/topic/279639-r9-280x-crashes-pc-help/#findComment-3835675
  • 2 weeks later...
pretty much try updating the Bios and check if you have enough power for it (wich i think u should have, since u had a 4870)
https://linustechtips.com/topic/279639-r9-280x-crashes-pc-help/#findComment-3912448
