First of all thanks soo much for even reading this.
Now to get into it...
Previous Components:
CoolerMaster Elite 310 Case
M5A78L-M/USB3   ( Motherboard )
Fx-4100 Cpu
No idea for Ram
Gtx 560 Ti 2gb
Crucial M500 240gb SSD  ( With OS installed )
500gb Hard Drive
New Components:  ( Only these things are changing, everything else the same )
AsRock Z97 Pro4 Motherboard
Intel Core i7 4790
CX 750 Watt PSU
Now i need to ask a few questions. Is their an obvious problem, that anyone can see with what i am planning to do ?
Also when i am going to upgrade , i am worried about RAM, and HDD interference. If i just move the SSD and HDD across to the new mobo and then install it into the case, will it work straight away or might there be a problem with the changing from AMD to Intel ?
Sorry if this is a little vague. If you would like any more info please ask, thanks for all the help.
https://linustechtips.com/topic/279158-upgrading-pc-help/
You will need to reinstall Windows.
https://linustechtips.com/topic/279158-upgrading-pc-help/#findComment-3787876
Well you will have plenty of power, if you plan on upgrading than that is good. What about RAM? If you right click My Computer and press properties, it will show you your computer specs. (Except the GPU) Do You have plan on using same GPU? Are you planing to get a new one? It probably will boot, but you may have to reinstall new intel drivers. You may also have to reactivate the windows license.
Honistly, i would just back everything that is important on to a the hard drive (assuming that isn't your boot drive) and reinstall windows on your SSD Then you won't have to worry about getting the AMD drivers off.
Thanks for the really quick response.
Just to quickly sumup ;
Backup SSD to HDD.
Install new hardware, boot up and re-install windows along with Intel drivers.
https://linustechtips.com/topic/279158-upgrading-pc-help/#findComment-3788166
