PC Build Help
Go to solution Solved by WoodenMarker,
Yes, the parts are compatible.
What's the system being used for?
Is the optical drive really necessary?
https://linustechtips.com/topic/278891-pc-build-help/#findComment-3779944
Mainly for playing games, and yes.
If you can stretch the pricing a bit, better: http://pcpartpicker.com/p/tcZHbv
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/278891-pc-build-help/#findComment-3780177
