how many different video players and drivers do you have installed?
what are you using for sound?
that last post.............. never, ever, heard this or experienced that before. when they move, are they bigger than they were before?
Only the ones for my current nvidia card, and no they just get moved like the screen resolution was forced to a smaller resolution then going back when I restart?
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3778155
disable windows updates. disable windows auto driver updates.
uninstall the nvidia drivers (from add/remove programs).  reboot.  let windows find the card. do a custom install on the nvidia drivers. ONLY install the graphics driver and the physx driver. NOTHING else.
again, what are you using for sound?
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3778688
Did all that, and sound? just razors surround sound drivers that go with my kraken headphones. Dont have a sound card or anything
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3778793
no desktop speakers? what if you use your monitor speakers and temporarily disable or uninstall anything related to the head set? while also only having the two nvidia drivers installed.(physx and graphics)(pull headset jack)
Nope, never needed speakers :P And alright Ill give it a try.
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3779168
now you need a set. hard to believe your monitor doesn't have a any. I hope you're uninstalling stuff or disabling stuff as suggested as we go or we won't find a cure. OPEN the control panel and look under sound to see how many different options there are for sound.
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3788409
by the way, that includes CHROME! i see another person suggests a different browser. 2 people can't be wrong.
next thing you can try is a system restore. I hate to use those before actually finding a solution but your machine is in your hands not mine. copy whatever you need to a disc or drive before doing so. go back to a time before this stuff happened.
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3788451
Really? So if two people suggest you ignite your computer, they're automatically right? That's a seriously flawed statement. System Restores are only so useful. If the hardware is having issues, it won't do any good.
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3788466
you use chrome? I tried it. worst thing I ever used. we're trying to  eliminate potential problems. if OP doesn't do things it won't get us anywhere. I also think it's software related at this point. unfortunately the "online" fix is taking longer than antisipated.
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3788488
I have used Chrome for a while. No issues. But again, your statement was highly flawed.
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3788507
Only thing under sound is my headset.
I have done many system restores in the past to try to fix this issue with none working, another one probably wouldn't fix the issue.
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3789606
That application doesn't want to install, just times out everytime. Also if its just a driver updater a person earlier posted one that I used and only had one driver outdated which is fixed now. Also earlier I stated I have reformatted before with it not helping the problem at all.
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3791157
Have you tried resetting CMOS to see if that will fix your BIOS settings? There's obviously something going on there that shouldn't be. Take the battery out of the mobo then put it back in. I don't know much about AMD, but have you ever overclocked the CPU? maybe it's just worn out. OCing is guaranteed to shorten the life of your hardware.
Your attitude determines 100% of your life's outcomes. Bad Attitude, bad life. Great attitude, great life.
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3792281
I never tried to OC, BIOS automatically enabled some OC-like settings along time ago without telling me and probally reduced its life.. Its currently has every setting that OC's the CPU to off. I can try taking out the battery. See if it does anything to help.
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3792445
Have you got the latest drivers? Try updating all your drivers. A good application for this is Driver Booster.
http://www.iobit.com/driver-booster.php
OP please do NOT download this software. iobit are very widely known for infecting people with malware and are just a fishy company in general. Diver update programs can seriously mess up your PC to the point of operating system corruption so bad you are forced to wipe and reinstall.
It is really best and safest to install drivers manually or by ONLY using software provided directly from the manufacturer.
Intel Core i7-4790k | 16GB HyperX Fury | EVGA GTX 1080 FTW
The work you do while you procrastinate is probably the work you should be doing for the rest of your life. -Jessica Hische
https://linustechtips.com/topic/278424-cpu-problems/page/2/#findComment-3792452
