Hi guys! I've been having issues with my hp laptop (pavilion g7) since quite a while but I didn't find the answer to my problem anywhere else, so I thought I'd give it a try here, since I've been following linus and the forums for some time!
So here's the issue: Each time I plug the power adapter in my laptop, it says "plugged in, not charging". If I want it to charge, I need to remove and reinsert the battery while it's plugged in. Is there any way to fix this?
Thank's in advance,
Wasn't sure in which category to put this..
https://linustechtips.com/topic/278371-hp-laptop-battery-problem/
Thank's in advance,
Have you given it the old "have you tried turning it off and on again"? This happened on my laptop once and this is how I solved it.
Try to borrow a battery of same from your friend or someone else and check it!
Else the borrow the charger and do check it.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
