where can i get some green LED 120mm and 140mm good fans. and Green LED lighting. :D
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
https://linustechtips.com/topic/27837-led-case-fans/
Anywhere. Mircrocenter if you want to physically go there or any tech set, Newegg, NCIX etc or Amazon
OS - Windows 8.1 Motherboard - ASUS M5A99FX Pro R2.0 Processor - AMD FX 8350 Black Edition RAM - 16GB 2x8 Crucial Ballistix Sport Graphics Card - Gigabyte Windforce 2 OC GTX 660 Power Supply - Corsair CX750M CPU Cooler - NZXT Kraken X60 Wireless Adapter - ASUS PCE-N15 PCI-E Adapter Fans - x3 Masscool blue LED 120mm Fans Case - Fractal Design Define R4
Monitor - Dell S2230MX 21.5-inch Keyboard - Logitech G105 Mouse - Logitech G602 Speakers - Logitech Z130 Headsets/Headphones - Tt eSports Shock, AKG K240, California Headphones Laredo Phone - iPhone 4S
https://linustechtips.com/topic/27837-led-case-fans/#findComment-353896
i know i can look on Newegg and stuff but i dont know witch brands are good :P
https://linustechtips.com/topic/27837-led-case-fans/#findComment-353900
thanks :D
https://linustechtips.com/topic/27837-led-case-fans/#findComment-353917
I would recommend getting normal fans and then getting LED strips. You'll end up with better stuff.
It's kind of like: do you want a vehicle that goes really fast on land or really fast on water, because you can get one that does both, but it won't do that great for either .
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/27837-led-case-fans/#findComment-354131
ok another question. could you hook up fans to a BitFenix Recon Controller, and the LED's on the Fans to a Colossus Case LED controller?
https://linustechtips.com/topic/27837-led-case-fans/#findComment-354172
Good LED case fans would be Bitfenix Spectre (non-pros) and Yate Loon D12SL.
Why nonpros? You mean for airflow I presume?  As the pros are more static pressure based
Specs: Core I7-2600K @ 4.5GHz @ 1.35V, 4x4GB Corsair Vengeance Black 1600MHz CL9, Cooler Master Evo 212, MSI Z77 Mpower Motherboard, Sapphire Radeon HD 7950 Vapor-X @ 1000/1400, Cooler Master HAF 932 Blue Edition w/ 3 Cougar Hydraulic Bearing 120MM fans (2 up top 1 in the bottom) replaced side panel with a window, and rear fan with a Cougar Hydraulic Bearing 140MM, Cooler Master GX 650 80+ Bronze PSU, Samsung DVD-RW, Samsung 840 Pro 128GB SSD, Seagate 750GB SATA III 7200RPM
https://linustechtips.com/topic/27837-led-case-fans/#findComment-354236
no i will be using the Spectre LED fans and i was wondering if i could conect the fans to the fan controler and the LED's on the fans to the case button thing :P
https://linustechtips.com/topic/27837-led-case-fans/#findComment-354245
I have never tried them myself (and I guess it's too late now) but Enermax have some really nice looking LED fans.
Those fans are really loud and from what I've heard, the bearings don't last too long.
I have been using two of those for two years, they're definitely not quiet running at 1000RPM but I've had no other problems with them.
https://linustechtips.com/topic/27837-led-case-fans/#findComment-354909
cm slickflow
They are vacuum cleaners.....don't have cable extension so they are always at full rpm...
AMD Radeon 7870 Gigabyte OC / Intel i5 3570k / ASrock Z77 Pro4 /Samsung 840 EVO 250GB / WD Blue 500GB 7200rpm / Kingston HyperX T1 2x4GB 1600mhz / SeaSonic 520w M12 / Thermaltake v4 Black
https://linustechtips.com/topic/27837-led-case-fans/#findComment-355057
