need help C++
Go to solution Solved by WanderingFool,
Well I agree that you solved it, but your original code was cleaner and easier to edit for the task.  You just have a few simple mistakes, by the looks of things.
I'll quickly go through your original code, adding comments
#include <iostream>using namespace std;int main(){int num,first,second;cin>>num;second=num;first=num;while(num>0)   {    cin>>num; //So you are pretty good up to now, including this line.,,from here you start getting into trouble    //So if you want things like -1 to count towards the lowest, then everything is fine.  Although if you didn't, -1 would be consider in the later    // if statements, so I would recommend just breaking here when num < 0    //if(num < 0) break; at least one problem solved    //So there are effectively 3 scenarios here that you want to "deal with".  num > second > first, second > num > first, and second > first > num    //The first doesn't really matter much, as nothing changes, the second one is important, but the third is effectively where everything happens    //so from now on I am assuming second > first > num (actually lets make num = -1 and second and first = 10)    if(num<second) //So this is semi-alright  *explained later*    {        second=num; //Over writing second, this makes sense for now...as num is less than second        if(second<first) //So when second is lower everything is good.        {            first=second; //Now the problem surfaces, you already set second = num...now you set first = second, so first = second = num            //Actually this problem is pretty easy to solve though, just perform a swap...since second >= first always, swapping will still make that true.            //something like            //num = second; first = second; second = num; would actually work...instead of your first = second line        }    }}cout<<first<<endl<<second;}
So essentially your original code could be fixed by inserting just 4 simple lines of code, 2 for if break; and 2 for swapping (swapping is normally 3 but you already have one line of the swap code)
#include <iostream>using namespace std;int main(){int num,first,second;cin>>num;second=num;first=num;while(num>0){    cin>>num;    if(num<second)    {        second=num;        if(second<first)        {            first=second;        }    }}cout<<first<<endl<<second;}
it's suppose to print the smallest 2 numbers but it just print the last negative number
Edit : arrays solved it -_-
#include <iostream>using namespace std;int main(){int x[1000],num=0,v;for(int i=0;i>-1;i++){    cin>>x[i];    num++;    if(x[i]<0)    {        break;    }}for(int j=0;j<(num-1);j++){    for(int h=(j+1);h<num;h++)    {     if(x[j]>=x[h])      {        v = x[j];        x[j] = x[h];        x[h] = v;      }    }}cout<<x[1]<<endl<<x[2];return 0;}
https://linustechtips.com/topic/278256-need-help-c/
0b10111010 10101101 11110000 00001101
https://linustechtips.com/topic/278256-need-help-c/#findComment-3773044
That was a huge help thanks :D
https://linustechtips.com/topic/278256-need-help-c/#findComment-3773123
