Yeah, you're definitely looking at a headphone amplifier here.
I have two questions for you if you're going down that route:
  • Do you have a specific budget?
  • Do you want a portable one (battery) or one that plugs into your USB for power?
Compatible with Windows 95
https://linustechtips.com/topic/277980-audio-question/#findComment-3770016
