Any decent cable will do. Amazon got lots of option, just use the right keywords.
First you gotta know the connector type first. Check with the manual if necessary.
https://linustechtips.com/topic/277652-cable/#findComment-3766988
XLR female to jack, or if you want to get the full quality you will need to buy an audio interface like myself: http://www.amazon.co.uk/3-5mm-Laptop-Female-Mixer-Speaker/dp/B003OSYYOS/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1419657905&sr=1-1&keywords=xlr+female+to+3.5mm
https://linustechtips.com/topic/277652-cable/#findComment-3770671
https://linustechtips.com/topic/277652-cable/#findComment-3771556
