https://linustechtips.com/topic/277573-fittings-help/
Depends.. Can't help you out if you don't tell me how many components and direction changes you have mate. Every component water block require two fittings (IN and OUT).
Do you have a plan drawn out?
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/277573-fittings-help/#findComment-3766625
No
How do i draw a plan?
ps:Im a noob
I create free buildlog banners.Want one? Go to my shop http://linustechtips.com/main/topic/378798-free-buildlog-banner-shop/#entry5119483
https://linustechtips.com/topic/277573-fittings-help/#findComment-3767010
No
ps:Im a noob
Most people find a good pic of the internals of the case they want to use and draw the tubing runs etc. With paint or something. I highly recommend you plan out your loop before starting.
Example:
https://linustechtips.com/topic/277573-fittings-help/#findComment-3767111
60 fittings is either waaaaaaay to many or your building a quad sli cpu 4 rad res and seperate pump build and still want left over fittings.
I am the one who goes bump in the night... usually making a sandwich.
Case: Phanteks Enthoo Primo White - Motherboard: ASUS X99 Deluxe - CPU: Intel i7 5820k - RAM: 4x4GB Corsair Vengeance 2666mhz ddr4 - GPU: Dual EVGA gtx 980 SSC - PSU: EVGA G2 Supernova 750w - Cooler: Custom PETG Loop on cpu and gpus - Storage: 500gb Samsung 850 evo ssd, 2x Seagate Barracuda 7200rpm 3tb hdd
https://linustechtips.com/topic/277573-fittings-help/#findComment-3769336
Dude....what are you going to be needing 60 fittings for.........I have a CPU/GPU loop, with 2 radiators, a separate pump and res, and only need about 10-12 fittings......even if I added another GPU can't see it being more than 15.........
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/277573-fittings-help/#findComment-3770096
I've got a pretty big loop, and i'm lucky to have more than 26-28 fittings.
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/277573-fittings-help/#findComment-3770154
