First Ever Build
Go to solution Solved by Damikiller37,
I know the parts are outdated. But Theoretically would it work?
Right there are a couple things that are off with the build you are asking for. Firstly the processor won't work with that mother boards since they use a different socket. The CPU is a few generations old and the Motherboard is the latest generation. Since this is a z97 motherboard you should be looking at Haswell and Haswell Refresh processors. 16gb of RAM will only be useful if you plan on editing or doing several demanding tasks while gaming which is why I would suggest buying an 8gb kit instead unless you plan on editing with the system. It will save you money and you will be able to put it somewhere else. Unless you have a very good reason why you would want Windows 7 over 8/8.1 then you should get 8.1 instead since it will be better for the future. Also the storage, I would advise that you get a 250gb SSD for your OS and software and have a HDD for your games.
Not giving a budget isn't very helpful when someone wants to tell you what to get so I followed the build you have and it would be somewhere in the $1400-1500 range. Here is what I would suggest you get for that money:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($234.99 @ Newegg Canada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ NCIX)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($168.98 @ Newegg Canada)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($78.98 @ DirectCanada)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($129.89 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ DirectCanada)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($409.99 @ NCIX)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($109.99 @ NCIX)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($64.99 @ NCIX)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($113.42 @ DirectCanada)
Total: $1391.21
Generated by PCPartPicker 2014-12-26 09:02 EST-0500
This system will be a much better choice both aesthetic wise (subjective to my personal preference) as well as price wise. I have picked trusted and solid parts as well as applied all of the things that I have mentioned above. I made sure you will have to buy parts from as few retailers as possible so I kept it down to NCIX, Newegg and Tiger Direct.
P.S Just in case you didn't know of PCPartPicker then that is what I have used to make the part's list. The website allows you to match up all of the components and has a compatibility filter so you will know which parts are compatible since it will filter out all of the ones that aren't as you keep adding parts. Also to export the list for the forum you have to click the "Export / Markup" button in the top right corner of the website, then select BBCode in the "Format:" section then copy all of the code and paste it when you are making a comment. To see the links while still writing the post click this button: 0598d27231.png in the post editor twice and it should appear formatted just like the one I have pasted above.
I've Decided to Build my very first computer. I've pretty much settled on all the parts but would like to have some input from others.
The parts are as Follows.
Windows 7 Profesional 64bit
ASUS Z97 Sabretooth mk1 motherboard
ASUS Strix GTX 970 GPU
Intel Core i7 2600 CPU
intel 730 - 480 GB SSD
Corsair Vengence 16 GB RAM
Antec EDGE 550 PSU
Antec ElevenHundred Chassis
I'm Open to suggestions for things that perform similar at a lower cost or better at a similar cost.
Also if there are any parts that wont work together i would love recomendations for replacements.
I would also like to know why they wont work together. For Educational purposes ;)
https://linustechtips.com/topic/277087-first-ever-build/
Why do you need windows 7 professional???
https://linustechtips.com/topic/277087-first-ever-build/#findComment-3760236
ASUS Z79 Sabretooth mk1 motherboard
Antec EDGE 550 PSU
First of all most of those parts are outdated. What is your budget? What will it be used for? Gaming? Editing? Both? Also what country are you in so we can get the parts from your country's retailers for you?
https://linustechtips.com/topic/277087-first-ever-build/#findComment-3760251
Mostly Gaming. I Live in Canada and no real budget.
https://linustechtips.com/topic/277087-first-ever-build/#findComment-3760288
https://linustechtips.com/topic/277087-first-ever-build/#findComment-3760502
Total: $1391.21
https://linustechtips.com/topic/277087-first-ever-build/#findComment-3764906
Total: $1391.21
Alright. Thanks for the input. this looks way better than what i was doing.
https://linustechtips.com/topic/277087-first-ever-build/#findComment-3766213
