Transfer
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/277052-english-grammar-question/#findComment-3759881
Is it transfer from a school to another Or convert from school to another !?
transfer
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/277052-english-grammar-question/#findComment-3759882
and convert is wrong or the most common is transfer !?
Convert is wrong
https://linustechtips.com/topic/277052-english-grammar-question/#findComment-3759890
Sorry for asking too much but does the same apply on college !?
Yes
https://linustechtips.com/topic/277052-english-grammar-question/#findComment-3759906
Transfer infers an item is moved from one place to another
Convert infers an item is changed from one state to another.
Main Rig:-
Server:-
https://linustechtips.com/topic/277052-english-grammar-question/#findComment-3759914
 Technically speaking I'm not sure, however I'd say convert is wrong.
When you transfer from something to another, Its not really a big deal.
However when you convert its a big deal.
Example. "I transferred from xbox to playstation"                   "I converted from console to PC"
"I transfered from this school to this school"                         "I converted from christianity to buddhism"
https://linustechtips.com/topic/277052-english-grammar-question/#findComment-3759917
The concept behind "transferring" schools is that you are taking all of your grades and academic history and transferring them to another school. "Converting" usually means that your changing the nature of something. You can convert MP3 files to WAV files. While they are both audio, they have been converted to a different type of itself.
That might have sounded overcomplicated. If so, I apologize.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
https://linustechtips.com/topic/277052-english-grammar-question/#findComment-3759949
