Hello, I am curious if AMD's single threads per core are as good a s intel's dual thread per core.  I just don't want to buy an AMD quad core and get the performance of a dual core intel is what I really want to know. It seems simple, but why aren't there 4 thread cores if you look at it in a different perspective. Die size?
https://linustechtips.com/topic/276889-threads-and-multitasking/
To my knowledge there is no way to measure actual tread performance, I think their both the same. On the other hand Intel single core performance has the upper hand while AMD tends to lean towards more cores for better performance... At the end of the day what will you be doing? What games do you play? Will you multitask a lot?
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3758220
Intel has better performance per core, but with AMD you can buy more cores with less money. The FX 8350 has 8 cores for $160. Whereas the only Intel processor(s) with 8 cores is over $1000. But do you really need the 8 cores?
PCPartPicker Part List: https://pcpartpicker.com/list/THNVZf
CPU: Intel Core i5-8600K 3.6 GHz 6-Core Processor  ($244.00 @ B&H)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.95 @ Amazon)
Motherboard: Asus ROG STRIX Z370-F GAMING ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($84.99 @ Best Buy)
Storage: ADATA XPG SX6000 Pro 256 GB M.2-2280 NVME Solid State Drive  ($51.99 @ Amazon)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive  ($164.00 @ Amazon)
Video Card: Zotac GeForce GTX 1080 8 GB AMP! Extreme Video Card
Case: Fractal Design Define C TG ATX Mid Tower Case  ($104.98 @ Newegg)
Power Supply: Rosewill 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($139.99 @ Other World Computing)
Monitor: LG 32GK650F-B 32.0" 2560x1440 144 Hz Monitor  ($396.99 @ B&H)
Total: $1276.89
Generated by PCPartPicker 2020-04-12 03:07 EDT-0400
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3758222
Intel uses something called Hyper Threading it isn't that great but it isn't that bad either, 4 cores / 4 thread are generally better than 2 cores / 4 threads, Intel has better IPC and FPU performance too.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3758223
AMD cores share resources.  In integer calculations it is a quad-core, in floating point calculations it is a dual-core since each pair of cores only has one integer unit between the two of them.  In real world performance it's somewhere between the two, more heavily weighted toward one side depending on the kind of applications you're running and what kind of operations they use.
Intel's hyperthreading can benefit, but again it is application dependent.  Sometimes you get no benefit at all, sometimes it's a nice boost.  But it's never as good as a real quad-core.
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3759410
I just want a cheap and semi-future proof moderate gaming processor. I am considering buying an AMD Athlon II X4 630 Quad-Core Processor Socket AM3 2.8GHz ADX630WFK42GI and overclocking it to 3ghz
That is not modern, and not good at all.
Ideally, you want an i5.  If you can't afford an i5, get an i3 as it still has 4 threads.  Also, with Intel, you have an upgrade path for the future, you don't get this with AMD.
What is your overall budget?  Where are you located?  Do you have any components you can reuse?  Do you need operating system? Monitor? Peripherals?
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3761415
I just want a cheap and semi-future proof moderate gaming processor. I am considering buying an AMD Athlon II X4 630 Quad-Core Processor Socket AM3 2.8GHz ADX630WFK42GI and overclocking it to 3ghz.
You're best off getting the AMD A10 7850K if you're struggling with the budget.
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3766892
Are you saying Enflics is wrong in the quote?I don't multitask with intensive apps. 3ghz at 4 cores with an r7 250 will not do much for the next 7 years at least?
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3767164
I don't think anyone's wrong here, but you've yet to say what you will be using this PC for.
Total: $1276.89
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3768156
A PC that can have multiple chrome tabs open while playing a game like War frame at 35hz or more with not dips in fps at at least medium settings.
Quad core should be enough for that then. An i5 or i3 if you're low on funds should do you right. For gaming especially, the i5 4690k is the best gaming processor on the market at the moment.
Total: $1276.89
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3768332
Is that much superior to the cpu I asked about AMD Athlon II X4 630 Quad-Core Processor Socket AM3 2.8GHz ADX630WFK42GI ?? It is cheap used on ebay.
Oh definitely. The 4960k is $220 but is undoubtedly a lot better than any Athlon processor. Like I said, if you're not willing to spend that kind of money, go with an i3. They only have 2 cores, but the 4150 has many more determining factors over that particular processor. The performance per core is much better than having more of them. Or if you'd prefer more cores at still a low price an i5 3570k or FX 6300 works as well.
Total: $1276.89
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3768626
  • 3 weeks later...
https://linustechtips.com/topic/276889-threads-and-multitasking/#findComment-3950344
