So right Specs right now are:
  • CPU
    Intel Core i5 2500S
  • Motherboard
    P8Z77-V LX
  • RAM
    Kingston HyperX 4x2 Dual-Channel
  • GPU
    MSI GTX 970
  • Case
    ThermalTake urban s31 snow edition
  • Storage
    WD Blue 1Tb
  • PSU
    ThermalTake Smart Standar 550W
  • Display(s)
    HP 2310m
  • Cooling
    Corsair H100
1. Upgrade my CPU to the i7 3770k.
2.Upgrade my Monitor to the Asus VG278HE.
3. Upgrade my PSU To a 800w one.
Which one should i get first?
I was thinking on the monitor then the cpu then the PSU.
https://linustechtips.com/topic/276618-help-on-upgrades/
Sounds like you already have a solid plan. Though to be honest, unless you get an absolutely killer deal (under $150) for the CPU I wouldn't bother buying one.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/276618-help-on-upgrades/#findComment-3755040
GET AN SSD
/thread
...how did I miss that?!
THIS THIS!!! ^^
https://linustechtips.com/topic/276618-help-on-upgrades/#findComment-3755071
It is not needed in a gaming rig.  OP is your main focus with this pc gaming??
His main focus should be a general upgrade and an SSD is.
https://linustechtips.com/topic/276618-help-on-upgrades/#findComment-3755095
Well then I say get a nice IPS monitor and call it done until you can save up for better stuff. Nothing is wrong with your PC and your performance should be pretty good too.
https://linustechtips.com/topic/276618-help-on-upgrades/#findComment-3755162
Are they any 144hz ips monitors? I forgot to mention i play o lot of shooters From csgo to Bf4
https://linustechtips.com/topic/276618-help-on-upgrades/#findComment-3755174
3TB or more hard drive. I'm already running low on my 1TB HDD filled with nothing but games x3.
Mid-range Emulation Gaming and Video Rendering PC
[CPU] i7 4790k 4.7GHz & 1.233v Delidded w/ CLU & vice method [Cooling] Corsair H100i [Mobo] Asus Z97-A [GPU] MSI GTX 1070 SeaHawk X[RAM] G.Skill TridentX 2400 9-11-11-30 CR1 [PSU] Corsair 750M
https://linustechtips.com/topic/276618-help-on-upgrades/#findComment-3755175
Well, I know what I'll be needing for an upgrade.
Still using an old Dell keyboard from 2004. Don't think mechanical keyboards are even worth the price yet :P.
https://linustechtips.com/topic/276618-help-on-upgrades/#findComment-3755235
The Cpu has been 200$ for months on my local tiger direct :P
Yeahhhh but the 4790k is like $249 if you look around.
It's not really worth it for $200.
https://linustechtips.com/topic/276618-help-on-upgrades/#findComment-3755320
Ehhh i just dont  want to upgrade my mobo im to lazy QQ #FirstWorldProblems
Eh, laziness will cost you in the long run.
https://linustechtips.com/topic/276618-help-on-upgrades/#findComment-3755346
