Hi, I've been having problems with my 290 and gigabyte say they cannot find a problem with it.
There is enough power going to it, and I've tried it in multiple builds with different monitors and cables (DP, HDMI, DVI-D), OS (Win7, Win8/8.1, Win10, ubuntu), and different drivers and versions of catalyst. It causes crashes, and lots of visible anomalies.
Images and videos of some of the visual problems.
https://plus.google.com/photos/112163720573973543741/albums/6096267341290888993?authkey=CMbvm4725fHKdA
Any idea on the specific causes or possible fixes?
https://linustechtips.com/topic/276032-r9-290-problems/
Looks really obviously like a dead card :l are you getting bluescreens or anything? or just the visual anomalies, which COULD have something to do with drivers, but seeing as you accounted for that I really can't say anything more than it must be a hardware problem if you're experiencing the same thing with different builds and different monitors.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/276032-r9-290-problems/#findComment-3748036
Which revision is it?
The original model was reported to have issues with vram and all that stuff.
Revision 2 was fine.
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/276032-r9-290-problems/#findComment-3748042
