SpeedFan ramps up my fan to full speed under load
Solved by Pyr0monk3y,
Speed fan has a feature that sets all fans to 100% if any temperature goes over the "alarm temp". You need to make sure all of your sensors' alarm temps are set above normal operating temperatures.
1
3
srrrx ·
Posted in New Builds and Planning5 -
2
5
7
