CPU fan error
Go to solution Solved by X1XNobleX1X,
That's kinda silly. Can I just plug the pump into it or does it really need to be a fan?
Oh, yeah that is what should be plugged in.
Hi,
Just built a new PC with an Asus Maximus VII Hero mobo and 4690K. I have a waterblock on it and have the onboard fan controllers disabled but keep getting an error  for the CPU fan on boot up and it makes me go into the bios everytime Windows starts. Is there a way around this issue?
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/275397-cpu-fan-error/
Hi,
Have you plugged your fan into the CPU_Fan header? (The one on the top right.)
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/275397-cpu-fan-error/#findComment-3739645
No fans are plugged into the motherboard.
https://linustechtips.com/topic/275397-cpu-fan-error/#findComment-3739652
Ignore this thread and use the other one please.
Sorry for the double post.
https://linustechtips.com/topic/275397-cpu-fan-error/#findComment-3739655
You need to plug atleast one fan into the CPU_Fan header or the PC won't boot past the bios.
https://linustechtips.com/topic/275397-cpu-fan-error/#findComment-3739657
https://linustechtips.com/topic/275397-cpu-fan-error/#findComment-3739667
https://linustechtips.com/topic/275397-cpu-fan-error/#findComment-3739672
CPU_FAN is for your pump
CPU_OPT is for your Radiator Fan
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/275397-cpu-fan-error/#findComment-3739677
