What is the difference between the rear motherboard audio interface versus the front ones?
Are they driven from the same audio chip?
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/275286-front-vs-read-audio/
I'm using headphones and the sound is a bit funny when I connect to the rear audio jack (line out). It doesn't sound like stereo. There is a hint of this annoying surround sound effect.
60FPS Microwave
https://linustechtips.com/topic/275286-front-vs-read-audio/#findComment-3738233
The DAC chip driving them is positively the same. The amp, depending on the manufacturer/brand, can be the same or not the same. Some brands include a headphone amp to one of them, either the front or the rear one.
The difference is, the back jacks are part of the mobo, while the front panel is part of the casing. Most casings uses cheap stuffs, i.e. thin and bad cables, cheap front panel PCB, and stuffs. Moreover, that thin cables run from the back part, across the middle of the mobo to reach the front panel, picking up interference along the way.
https://linustechtips.com/topic/275286-front-vs-read-audio/#findComment-3738240
Ah, unless stated otherwise, don't plug it into line out jack. Line out jack output at line level, which is only ideal to use with amps. Plug it to the front speaker jack
https://linustechtips.com/topic/275286-front-vs-read-audio/#findComment-3738250
Figures. My motherboard is capable of 7.1 surround and in the manual it states that I plug into the line out port for headphones and 2 channel speakers.
A jellybean NE5532 amp is included but I think its only for the front panel audio.
60FPS Microwave
https://linustechtips.com/topic/275286-front-vs-read-audio/#findComment-3738295
Well, if it's stated in the manual to plug headphones in the line out port, then it's okay.
Try checking the audio driver application, and turn off all effects. Then try wiggling or replugging the connector.
https://linustechtips.com/topic/275286-front-vs-read-audio/#findComment-3738312
Yes AsRock mobos typically amp the front so it might be better to plug it in the front.
https://linustechtips.com/topic/275286-front-vs-read-audio/#findComment-3739354
The NE5532 is quite a good op amp.  The realtek audio manager should allow you to select headphones as the connected device to the blue socket which should kick up the output from the opamp.
If you are unsure, select jack sensing and then plug in your headphones.  A dialogue box should appear asking what you plugged in and select headphones.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/275286-front-vs-read-audio/#findComment-3739536
Thanks for all the replies. I'll be using the rear output and I'll be buying an amp.
60FPS Microwave
https://linustechtips.com/topic/275286-front-vs-read-audio/#findComment-3740060
