hello ,
im looking for some help on overclocking amd fx8320 processor. ive never done cpu overclocking before and im a big gpu overclock head. so ive decided to squeeze some performance out of fx8320 but it is a bit difficult than i thought it would be im currently running on a asrock 970 extreme 3 r2.0 (...meh...) it does not have a friendly bios to begin with. if some one worked with the asrock bios please let me know what and how to do the stuff in it.
cheers,
sam
CPU: FX8320 @ 4.2GHZ, GPU: R9 390 PCS+Cooler: Hyper 212 Evo, MotherBoard: ASRock 970 Extreme 3 r2.0, PowerSupply: EVGA 600b 80+Bronze, Storage: seagate Barracuda 1TB SSHD & Case: Corsair Carbide 200r
https://linustechtips.com/topic/274822-help-on-ocing/
I'm using an ASRock Z97 BIOS. If it's anything alike, find your CPU multiplier, or some thing of the such, and change the ratio. Yours should be 35. If you want 4 GHz, put 40. If you want 3.8 GHz, put 38. I'm sure you get it from here.
CPU: i7 4790k @ 4.6 GHz Motherboard: MSI SLI Plus Krait Edition RAM: 16 GB (2x8) 1866 MHz Kingston Black Fury Series GPU: Gigabyte GTX 970 G1 Gaming Case: NZXT S340 (Black) Storage: Intel 730 Series SSD (240 GB), Seagate Barracuda (1 TB) Display: LG 24MP55 Cooling: Cooler Master Hyper 212 Plus Keyboard: Corsair K95 RGB for gaming (1st Player Fire Dancing for typing) Mouse: Logitech G502 Sound: Corsair Gaming 2100 Vengence 7.1 Headset Operating System: Windows 10
https://linustechtips.com/topic/274822-help-on-ocing/#findComment-3731281
What cooler are you using?
You shouldn't try pushing any FX processors without a good third-party cooler.
Also, please 'Follow' your own posts, above the 'Reply to this topic' button.
hyper 212evo i think its a good cooler.
https://linustechtips.com/topic/274822-help-on-ocing/#findComment-3731298
your bios looks way diff and better.
https://linustechtips.com/topic/274822-help-on-ocing/#findComment-3731302
