No.
The 6600k does support eyefinity with up to 3 displays.
But if i have another one of the s20b300b it would work?
The monitor choice doesn't make a difference.
https://linustechtips.com/topic/274741-help/#findComment-3731591
As long as you have the outputs available on your board to match the monitor, typically 1 HDMI 1 VGA and 1 DVI is available.
I assume you're not gaming?
https://linustechtips.com/topic/274741-help/#findComment-3732076
