My Silent Z77 rig.
BlackOutCrisis
So I've had this built for awhile now but never taken pictures, so I decided to today and here they are. The build is as follows:
CPU: i5 3570k @4.3ghz
Motherboard: MSI z77a-g45
RAM: Corsair Vengeance LP 2x4gb
GPU: MSI twin frozr 3 7950
CPU cooler: Cooler Master 212 Evo
PSU: Corsair CX750m
Case: Antec p182 in brushed aluminum
Sorry in advance if the pictures aren't that great. Also I didn't take any pictures of the case as it isn't a very flashy case and my floor around it is a mess lol
nice build and good specs
| Ryzen 7 3700x | 16GB Vengance @ 3200 | MSI GTX 1070Ti Gaming |
| ADATA XPG SX8000NP 256GB Nvme SSD + WD Blue 500GB SSD | 4TB WD Blue |
     | Corsair RM650x |
| NZXT H200 White |
Nice, but I heard that the Hyper 212 Evo isn't quiet.
It's not too loud, plus it's really cheap and it does its job fairly well.
Even the intel stock cooler is quiet @ idle to medium load as long as you set up a proper fan profile. (atleast on my brothers i3) ;)
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
I have my i5 undervolted so the fans never have to spin up since I get really good temps.
Looks very nice! Just curious, is your Twin Frozr a 6pin+6pin or is it a 6pin+8pin?
It is the old 6+8pin one. I'm really glad I managed to get this version because the MSI one uses their 7970 PCB.
lol my 2x 660 SLI uses 2x6 pins in total :)
Btw, like the Antec P Line of cases. Built 3 PCs in the P183
lol, but yea for as old as this case is I really enjoy it, definitely held up to the test of time. I have to admit I'm ready for a new case though haha
Just upgraded to the Fractal Design Define XL R2, its similar in looks like the P183 but more awesome. ^^
PS. You can find my build log in my signature. Not done, tho.
I have it, and it is a pretty good budget cooler, both for performance and silence.
MSI R9 290 Gaming | MSI Z77 MPower Big Bang | XFX Pro 750W Black Edition | i7-3770k @ 4.5GHz | Corsair H100i | GSkill Ripjaw 2x8Gb | NZXT Phantom 410 Gunmetal | OCZ 128 Gb Vertex 4 | Samsung 250Gb 840 EVO | 1&2 Tb Seagate Barracuda | Logitech G510 | Logitech G700 | Logitech G35 | 3 x LG E2442V
-it24-
Solid rig, but silent?  o you have padding on the doors? I don't see much for sound dampening (Silverstone's foam kit is a worthy $20 investment imo!).
Nice and clean build, you got there!
May I ask you what voltage you're running on your i5?
I'm interested in undervolting it as well.
Edit: Nvmd, my crappy board doesn't support undervolting :(
phanteks enthoo pro | intel i5 4690k | noctua nh-d14 | msi z97 gaming 5 | 16gb crucial ballistix tactical | msi gtx970 4G OC  | adata sp900
I believe the sound dampening material is in the middle of the side panels so it isn't visible.
Looks really nice and do you know what would make it look better sleeved cables
Yea I agree, I plan to get the sleeved cables for my psu from Corsair when I grab a new case.
I have it set to 1.184v. You should be able to change the voltages on that board, the setting in bios isn't called "undervolt" you just have to change the vcore to lower than stock voltages.
Yeah, and that's the problem. It doesn't have that option. It has Auto, +0,200.... and so on
Manually type in the voltage you want, you should be able to just use down arrow until you are at vcore then type the voltage you want.
Mhm... don't think this'll work, but it's worth a try. Thanks! :D
