Cheapest 120hz IPS monitor?
IMPERIUS
Hi!
What is the cheapest 120hz IPS gaming monitor? It must have hdmi for my ps4 and some other input for the pc. 23' or above. And please dont just list the cheapest one from pcpartpicker, I already took a look at it. And why does nobody list the monitor' refresh rate? Not amazon, not newegg...
Thanks
Longboarders/ skaters message me!
I don't think anything above 60Hz is available for IPS if I remember correctly.
"I take my spirit and I smash my mirrors,
And now the whole world is here for me to see,
Now I'm searching for my love to be."
-Jimi Hendrix, Room Full of Mirrors
Hi!
Thanks
IPS is max. 60Hz ATM. Also, for PS4 it won't have any benefit since its max output is 30-60 fps. If you have a PC that can push more than 60fps, that's something else. In which case the BenQ XL2411Z is a good one at a reasonable price.
Bert & Ernie before squirting spermie.
Why get a 120hz monitor for pS4? HDMI only shows up too 60hz...
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
I will be mainly gaming on my pc which will be able to push around 100fps in games and I also want to use my ps4 on the same monitor
No such a thing... IPS panels are slow, they usually don't go above 60Hz. If you want to go higher, you have to get TN.
LTT's unofficial Windows activation expert.
For IPS, you need to do a little more research mate, IPS overclocking panels are quite rare, but they have come back due to popular demand. Yamakasi Q270 2B is an example of IPS panel which can overclock. I have been out of the loop for a while now, but these panels obviously are the same panels that LG use in their monitors. So with a little research you could possibly find out which LG branded panel has the same board as this catleap Q270 2B and get that. That panel should overclock, you won't be guaranteed 120hz but this is your best bet.
I've included the link to the ebay page where you can buy them. They were selling for almost $1000 when they stopped making them. They replaced the 2B's with the 2C (which couldn't overclock) so they cashed in on the popularity of the 2B, but now they're back! Not sure for how long though. You should consider a PLS panel korean A- or not such as the PB278Q. PLS panels overclock better (IPS panels in my experience either overclock or don't).
http://www.ebay.com/itm/Perfect-Pixel-YAMAKASI-Catleap-Q270-2B-Extreme-OC-IPS-2560x1440-120Hz-Monitor-/111399828170?pt=Computer_Monitors&hash=item19eff27aca
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
You win for today >.>
lol i win haha
