I like to draw the line around 40C, but all of my stuff runs nice and cool as it is.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/273657-hard-drive-temps/#findComment-3716771
around 35-40C, mine runs at 25C so its alright
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/273657-hard-drive-temps/#findComment-3716777
Run CrystalDiskInfo. It will give you the temps of each drive and will tell you whether that's a good temp or not. A well built system will generally be in the green all of the time. Only externals get warm.
Sir William of Orange: Corsair 230T - Rebel Orange, 4690K, GA-97X SOC, 16gb Dom Plats 1866C9,  2 MX100 256gb, Seagate 2tb Desktop, EVGA Supernova 750-G2, Be Quiet! Dark Rock 3, DK 9008 keyboard, Pioneer BR drive. Yeah, on board graphics - deal with it!
https://linustechtips.com/topic/273657-hard-drive-temps/#findComment-3716909
Okay thank you for your help, will the SSD not run a little hotter?
HDD runs hotter because of the spinning platter. SSD heat is just from the electronics. My Intel 520 SSD does not even have a temperature sensor, so it might not be an important metric.
My comfort zone is also maxed out at 40°C, including externals. I even have a case fan dedicated to keeping my external drives cool during operation.
CPU AMD 7800X3D | Cooling Noctua NH-D15 chromax.black | Motherboard ASUS PRIME X870-P WIFI | RAM Corsair Vengeance RGB 6GHz CL30 32GB | GPU EVGA GeForce RTX 3070 FTW3 Ultra Gaming |
Case Fractal Design Define R5 | Storage Samsung 980 PRO 500GB, Samsung 970 EVO+ "v2" 2TB | PSU Corsair RM850x 2021 | Display ASUS VP247QG + Samsung SyncMaster T220 | OS CachyOS
https://linustechtips.com/topic/273657-hard-drive-temps/#findComment-3716968
Oh right good, thank you for such a developed answer for me hahah, it helped a lot, i appreciate it
https://linustechtips.com/topic/273657-hard-drive-temps/#findComment-3716993
A case with proper intake fans blowing over HDDs isn't going to make them hotter than 47-42C. Mine has been active about 4 hours while writing this. Highest temp for primary HDD is 33C, 10C above room temp, and it has been in use more than idle. I have 1 200mm fan keeping air flowing in.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/273657-hard-drive-temps/#findComment-3717025
