So I was making a plan for a build for my parents. as both there computers are starting to die.
They really only surf the web and my dad watches movies.
so they only really need a rig that will work and is cheap.
So I made these plans thinking that they will keep it for like 7 years like they have with our current PC
http://pcpartpicker.com/user/joelthezombie15/saved/1NjN
Im not to good at Uber budget builds so is that any good? They need a good bit of storage and they wont appreciate the SSD so i left it out. They also want as small as possible so i thought matx was a pretty good fit.
So is this good or can there be improvements?
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/27359-build-for-parents/
At one point I was going to use this in a build for my mum: 31lPTBabFJL.jpg
http://www.amazon.co.uk/Biostar-A68I-350-Deluxe-E350-mITX/dp/B0098QHRBM/ref=sr_1_7?ie=UTF8&qid=1371565480&sr=8-7&keywords=biostar+motherboard
In a bitfenix prodigy. It has a APU and is perfect for watching films and just browsing such :)
hello
https://linustechtips.com/topic/27359-build-for-parents/#findComment-347860
Eww biostar. i wouldnt trust them with crap.
the only thing i would change is the CPU, go with a AMD quad core FX series.  More cores are better for multi tasking and may help in adding a few extra years to its lifespan.
Well, im trying to keep it low budget.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-347864
just modified your config and did the quad core for less money.
http://pcpartpicker.com/p/17IdR
Ya i just chose a random case so, it could have been cheaper. thanks though
https://linustechtips.com/topic/27359-build-for-parents/#findComment-347886
Since it's for videos and web only, an APU would work just fine, wouldn't it?
Maybe you like it  ;)
http://pcpartpicker.com/user/TheIceCage/saved/1Nkd
Current Rig:    AMD FX 8350 @ 4.3GHz | Xigmatek Dark Knight Night Hawk Edition | ASUS Crosshair V Formula-Z | ASUS AMD Radeon HD7950 | 16GB Corsair Vengeance Red 1866MHz RAM
                          EVGA SuperNOVA NEX 750 Watt PSU | 2TB Seagate Barracuda 7200RPM | 128GB Samsung 840 Pro SSD | ASUS DVD Writer | CM Storm Trooper Windowed Edition
Peripherals:    BeyerDynamic Custom One Pro | Func MS3 | Steelseries QcK | Corsair Vengeance K70 Cherry MX Brown (on release)
https://linustechtips.com/topic/27359-build-for-parents/#findComment-347978
http://pcpartpicker.com/user/TheIceCage/saved/#savedbuild_415592
Changed it so there are 2 RAM-sticks, since it's dualchannel.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-348182
Great, thanks i will bring it to them.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-349566
Why a custom cooler?
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/27359-build-for-parents/#findComment-349787
Cause i just hate stock more than anything.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-351455
But if your not going to OC there is no point...
https://linustechtips.com/topic/27359-build-for-parents/#findComment-355290
Well that is ONE of the many problem with our current one, it is stock and it has been over heating and the system freaks out.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-355294
Ok cause my dad has a stock cooler running on his PC, and he got it when 1156 first came out so at least 4 years straight and never misses a beat, just blow some compressed air through it once in a while...but if it makes you feel more comfortable that that's cool.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-355321
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: AMD A4-5300 3.4GHz Dual-Core Processor ($49.98 @ Outlet PC)
Motherboard: Asus F2A55-M/CSM Micro ATX FM2 Motherboard ($78.98 @ Outlet PC)
Memory: A-Data Gaming Series 4GB (2 x 2GB) DDR3-1600 Memory ($37.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($64.99 @ NCIX US)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case ($39.99 @ NCIX US)
Power Supply: Corsair Builder 430W 80 PLUS Certified ATX12V Power Supply ($24.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($18.98 @ Outlet PC)
Total: $315.90
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-06-20 07:32 EDT-0400)
Anything past this Will be overkill for interwebz/movies
Its not your gaming rig of all your pride, Stock cooler will run just fine
Stuff I have I like: Moto G - Superlux HD681 Evo - Monoprice 9927
90% of what I say is sarcasm.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-355356
Since your parents aren't gaming and they want a pc to last a while, it'll be better to pour onto a better processor for overall usage. Intel is great for their faster cores.
Here's what I would do instead: http://pcpartpicker.com/p/18FR4
(and yes, I believe they wouldn't add an ssd if you asked them but the speed would be a pleasant surprise unless they're using linux.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359125
What is there current system? Intel or AMD? This doesn't apply to all CPU's or models, but most of the time I've found Intel's stock coolers to not really handle OC'ing over time very well at all; even just regular CPU speeds and it heats up unless you go aftermarket. I've been running an AMD Athlon II X4 620 @3.12GHz (Quad-Core, Stock speed is 2.6GHz) with the stock cooler/fan for almost 3 years now, and it idles/web browses at 30-35C normally. I've only ever pushed it to 57C when I was doing video encoding.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359160
That's awkward for the stock intel cooler. I find that temps are still very good as long as the case cooling is adequate.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359165
Well OK, you do have a point. Most of the Intel builds I've ever done have been in small cases, no dust filters, single fan, etc. El cheapo cases if you will, so that probably doesn't help much.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359191
Tried fitting a ssd into the budget, even an i3 will be overkill for interwebz.
CPU:  AMD A4-3300 2.5GHz Dual-Core Processor  ($37.99 @ NCIX US)
Motherboard:  Asus F1A55-M LE R2.0 Micro ATX  FM1 Motherboard  ($44.99 @ Newegg)
Memory:  Corsair 4GB (2 x 2GB) DDR3-1333 Memory  ($34.98 @ NCIX US)
Storage:  Crucial V4 64GB 2.5" Solid State Disk  ($61.68 @ SuperBiiz)
Optical Drive:  LG GH24NS95 DVD/CD Writer  ($14.99 @ Newegg)
Total: $324.60
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359597
buy this
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128585
the 847 cpu from intel is much faster than any APU or ATOM cpu
or the 1007U from intel
which is even faster than both of them
http://www.amazon.com/Gigabyte-Intel-Chipset-Motherboards-GA-C1007UN-D/dp/B00D1A8094/ref=sr_1_15?ie=UTF8&qid=1371812818&sr=8-15&keywords=1007u+intel
a D2700 is at 841 points
the 1007u is at 1600 points
the E-450 APU is at 900 points
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359624
Are you trolling or do you just not have a clue about this?
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359665
core values of the forum's code of conduct
  • Ensure a friendly atmosphere to our visitors and forum members
if you think there is something wrong with my suggestion
i will need more than "you just not have a clue about this"
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359684
I was asking, sorry
But a 2.5 GHZ Apu is quite obviously better than a 1 ghz Cpu.
The fact you benchmark them via Points (Which is a value that is non-existant for CPU's BTW) and compare the 1007 to a notebook cpu that was pretty bad 2-3 years ago make you seem kinda ignorant.
Try just looking at the product suggested before saying if it's worse or better than another product
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359730
I was asking, sorry
no problem i really want this forum to get better for everyone
1007U from intel was released in Q1 2013
Scroll to the bottom
1007U
http://www.cpubenchmark.net/cpu.php?cpu=Intel+Celeron+1007U+%40+1.50GHz
highest 1621
A4- 3300
http://www.cpubenchmark.net/cpu.php?cpu=AMD+A4-3300+APU&id=13
highest 1750
1007U's TDP is at 17 watts
while the 3300 is at 65 watts
EDIT:when i was saying worse or better i was talking about APUs (e-450 ) and atoms D2700
sorry for the confusion
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359751
1007U
highest 1621
A4- 3300
highest 1750
The TDP i because 1007U is a notebook CPU, not a desktop one
Didn't quite see that before
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359769
the 1007u is well hidden the only reason i heard about it was because Nas builders wanted something faster than the Atom cores but still low power
it seems only Gigabyte and a few small companies are selling these boards
they are quite powerful
https://linustechtips.com/topic/27359-build-for-parents/#findComment-359777
