Well my h100i broke.(the Blue and green LED is dead) so i need to order a cheap aircooler before i send my h100i in, any suggestions. prefer it to be easy to install and cheap./
im ordering from newegg as i can get free 2 day shipping there.
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/27326-cheap-air-cooler/
i here the hyper 212 is good for the money
Main Rig: CPU: 3570k Mobo: ga-z77x-ud5h-wb :RAM: 8gb kingson ddr3 1600 :gpu crossfire amd 290's Case: zalman z9 plus Cooler: h80i p/p SSD: nutron 120gb HDD: 2tb wd green 4tb seagate desktop
Girlfirends: CPU: 8350 Mobo 990fxa-ud3 Ram 8gb kingson ddr3 1600 gpu: his 7850 case: inwin dragon rider SSD: nutron 120gb HDD: 2tb seagate
https://linustechtips.com/topic/27326-cheap-air-cooler/#findComment-347336
+1
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/27326-cheap-air-cooler/#findComment-347337
hyper 212 it is. any differeence between plus and evo. all i can see is evo has a transparent fan and the heatpipes are close together
https://linustechtips.com/topic/27326-cheap-air-cooler/#findComment-347342
For the heatpipe reason, you should go for the Evo.
https://linustechtips.com/topic/27326-cheap-air-cooler/#findComment-347351
Hyper 212 is a good choice but I would recommend getting the Xigmatek Dark Knight, it performs better than the H80 and close to the H100 according to Tek Syndicate.
CPU: AMD FX-6100 Black Edition @3.9GHz GPU: XFX 7970 DD (1062/1520 MHz) MOBO: ASUS Sabertooth 990FXA(1st Revision) RAM: Corsair Vengeance 16GB @ 1333MHz Storage: Corsair Force 3 120GB(Boot) + WD Green 1TB(storage) PSU: FSP AURUM 600W(80+ Gold) CPU Cooler: Cryorig M9a  Case: NZXT Tempst 410 Elite(Mid-Tower) Mouse: Logitech G602(Manufacturer Refurbished) Keyboard: Noppoo Choc Mini(Cherry MX Blue) AUDIO:Sennheiser HD 598+ASUS Xonar DGX Monitor: LG M2280DF 21.5" 1080p(TN-75Hz)
https://linustechtips.com/topic/27326-cheap-air-cooler/#findComment-347352
well just by looking at the form factor, and linus's cpu cooling test video's numbers. i have to assume that it doesnt perform better then h100.(i guess i forgot to mention i have 4 noctua nf-f12s which i will be using)
https://linustechtips.com/topic/27326-cheap-air-cooler/#findComment-347425
dont you have a stock cooler laying around?
i kind of... threw it away.
https://linustechtips.com/topic/27326-cheap-air-cooler/#findComment-347426
I would just get the Hyper 212 Evo if you want to cool your cpu if it is overclocked. You can get a stock Intel cpu heatsink from other brands which is really cheap if you just want something to cool your cpu.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/27326-cheap-air-cooler/#findComment-349298
Hyper 212 EVO from Cooler Master.
| i5-4670k @ 4.2Ghz | Corsair H100i | Gigabyte Z87X-UD4H | Corsair Vengeance Pro 8GB | ASUS Geforce GTX 770 |
| Samsung 840 Pro 128GB | WD Black 1TB | Corsair AX760 | Fractal Design Define R4 Black w/ Window | Corsair AF140 x2 |
| Windows 8.1 | ASUS 23" 1080p monitor | CM Storm Quickfire Stealth- MX Blue | Logitech G9x | Logitech G930 |
https://linustechtips.com/topic/27326-cheap-air-cooler/#findComment-349512
the hyper 212 evo is for $30 and for like $22 you can get the respire t40 which isn't as good, but is a little cheaper if you just need it while you are RMAing your h100i
https://linustechtips.com/topic/27326-cheap-air-cooler/#findComment-350040
