Best performance airflow setup for NZXT Phantom 630 (Overclocking)
Solved by Giac,
I see... Hmm i'll think i'll retain the 212 instead and replace the original coolermaster fans. Can Corsair AP/SP's be mounted on the 212 evo?
Any 120MM fan will do. Because of the fairly low fin density on the 212 I would maybe lean towards AP120s instead of SPs.
Old_Liver ·
Posted in Laptops and Pre-Built Systems0 -
1
2
ghifrank ·
Posted in Troubleshooting0 -
V_1313 ·
Posted in Troubleshooting3 -
IR76 ·
Posted in Programs, Apps and Websites9 -
The Blue Cryptid ·
5
