So I will soon upgrade to an i5 4670k and after that to a GTX870 or HD9950(assuming they keep their naming schemes for once..)
And I have dreamed of a watercooled PC for very long now, so i want to make my dream come true, here are the parts I picked so far:
http://www.aquatuning.de/product_info.php/info/p9905_Mayhems-Pre-Mix-X1-Clear-1000ml.html
http://www.aquatuning.de/product_info.php/info/p3039_Alphacool-VPP655---OT12--G1-2--Au-engewinde-.html
http://www.aquatuning.de/product_info.php/info/p14776_EK-Water-Blocks-EK-D5-X-RES-140-CSQ---Acetal.html
http://www.aquatuning.de/product_info.php/info/p5405_Masterkleer-Schlauch-PVC-13-10mm--3-8-ID--UV-aktiv-White.html
http://www.aquatuning.de/product_info.php/info/p14453_Monsoon-13-10mm--ID-3-8--OD-1-2---Anschraubt-lle-gerade-Six-Pack---White.html
http://www.aquatuning.de/product_info.php/info/p15635_Aquacomputer-kryographics-f-r-GTX-780--vernickelte-Ausf-hrung.html
http://www.aquatuning.de/product_info.php/info/p15702_Phobya-CPU-Cooler-UC-2-LT-Intel-775-1155-1156-1oe-2011---Silver-Nickel-Black-Edition.html
http://www.aquatuning.de/product_info.php/info/p15480_Bundle-Alphacool-NexXxoS-XT45-Full-Copper-360mm--Standard--mit-3x-Yate-Loon-D12SL-12-1350rpm.html
http://www.aquatuning.de/product_info.php/info/p15479_Bundle-Alphacool-NexXxoS-XT45-Full-Copper-240mm--Standard--mit-2x-Yate-Loon-D12SL-12-1350rpm.html
Fans;
2 Silverstone AP 123 bottom rad intake PUSH
1 Noctua 140mm intake back
3 NF-F12 top rad exhaust PULL
This is my tubing-plan: (not sure which case to choose yet)
http://prntscr.com/1ail6t
My main Questions:
I am not sure which fittings to get for which places (45° or 90°)
The GPU block is just a placeholder
Will 2 compression fittings fit next to each other on the CPU-block?
Is one Liter enough for this loop?
How many metres of tubing will I need?
5x 120mm 45mm thick copper rad should be more than enough right?
Is everything compatible with each other?(Fittings, pump+res, etc)
I know this is a lot of input, but a response would be amazing :)
Also do you think it would be a good idea to get a CPU loop at first and later upgrade to a CPU and GPU loop or should I do it all in one go?
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
https://linustechtips.com/topic/27236-planning-watercooling-system-long-term/
Main Questions:
45 degree fittings would be good on the CPU block, but I don't think you REALLY need them anywhere else.
If you find out dimensions of the GPU block you want, and dimensions of fittings, you can work it out.
Tubing and coolant, no real way to tell.
Rads, should be more than enough.
Sorry, I'm not really experienced enough to go through all your parts and check for compatibility :P
Feel free to message me if you want to chat!
My main Questions:
45/90° fittings will be determined when the hardware is in the case. angle and tubing
changes drastically when the build is 90% finalized.
the comp fittings should be fine, the 3/4" are usually the offenders of interference.
coolant capacity is determined by radiator(s), tubing runs and reservoir capacities. usually
for the first, i encourage using distilled water first (cheaper), easy to access, and good for
new part flushing and testing. usually 1gallon bottle to start with. once everything is zero'd
out and functional, change to preference coolant.
we won't know about the TDP of the new GPU, until released. so it'll be a best guess and
that can cost even more hardship. generally, today's tech a 360x 60 can cool a CPUGPU
with some liberal overclocking with decent fan speeds.
compatibility hasn't been established, don't have a case, motherboard or system baseline.
to stab at it in the dark, any CPU block (1155 support), D5 pump, reservoir and tubing is
almost a written. what is left is case! very, very important decision. what looks the part for
and what has radiator support for the project?
airdeano
airdeano
Yeah the case is a hard decision, but I think I'll go for something like the NZXT Phantom 630, as it can have a 360mm rad in the top, a 240mm in the bottom and still have a couple HDDs
Does the motherboard even matter for the watercooling system? Unless it has a water cooling ready heatsink of course..
#KILLEDMYWIFE
