Hello,
I am planning a new build which I will use not just for gaming, but rather a multi purpose one including photo processing as well.
This is the basic setup which I have planned till now:
  1. Motherboard: Asus Z97-A
  2. CPU: Intel i7-4790K
  3. CPU Cooler: Corsair H100i
  4. RAM: Corsair Vengeance 1600 MHz (8GB x 2)
  5. GPU: Asus GTX 970 4GB DCU II DDR 5
  6. SSD: Crucial MX100 256GB SATA 3 SSD
  7. Storage Drive: Seagate 2TB 64MB SATA3
  8. Case: NZXT Phantom 410
  9. Power Supply: Cooler Master G650 Semi Modular Gold 7yrs
  10. Keyboard: Logitech G105 USB
  11. Mouse: Logitech G502 USB
I need  some help in evaluating how the setup will be. I am open to suggestions/ enhancements (but I am on a budget as well).
The things I am concerned about are: Motherboard (if it will be powerful enough) and power supply. Also how many case fans should I have (apart from the 3 stock ones given by NZXT)
Any help is appreciated.  :)
https://linustechtips.com/topic/272350-need-help-with-new-build/
Hello,
how much is your budget ? location?
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3694954
Hello,
Looks perfect to me.
In B4 "i5 instead of i7". But yeah, you could get by with an i5 just fine, but if it fits in your budget, the i7 is fine.
Motherboard is perfect, anything more than that isn;t going to be "more powerful". Just....prettier with features you don't need.
Someone else will reccomend a better PSU I'm sure. That one will work, but I think EVGA has a decent Gold rated PSU for good prices right now.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3694984
My location in Singapore, and my budget is around 1800 USD.
you def have a nice setup
but the H100i has plenty of issues which I suggest you avoid and opt for other brand of watercooler
is that PSU is V or G?
G are Bronze rated
V are the Gold Rated
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3694990
i don't know the pricing on singapore but here is it on USD
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($249.99 @ Micro Center)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($119.99 @ NZXT)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($138.99 @ SuperBiiz)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($59.99 @ Newegg)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card (2-Way SLI)  ($348.99 @ B&H)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($108.99 @ SuperBiiz)
Total: $1571.36
Generated by PCPartPicker 2014-12-18 02:33 EST-0500
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3695009
G are Bronze rated
Hi,
Sorry the PSU is a V650 (not G). I checked the online PSU Calculators, that the maximum wattage I might require is 450. So, keeping 200 as buffer in case I need an extra HDD or GPU later, I opted for the 650. Should I look for a better one?
Any suggestions regarding the watercooler?
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3695016
Hi,
which shop in sim lim square are you buying from?
I am from Singapore too :)
I will suggest the CoolerMaster Seidon 240M or 120XL
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3695039
Total: $1571.36
This
"I fart in your general direction" -The Frenchmen
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3695179
looks alright, I don't see anything that could be changed
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3695215
I will probably get it from PC Themes.  :) I normally follow the price lists published in hardwarezone.sg
Thanks for the suggestion!
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3695326
yea PC Themes/Fuwell/Video Pro are good shop
I just got a new PC from Video Pro for my dad
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3695332
Total: $1571.36
Great! Thanks for the suggestions! However, upon checking the prices in Singapore, its coming about 500$ above my budget!  :(
But apart from that, is the MSI Gaming 5 better than the Asus Z97-A? They are almost the same price!
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3695350
if you like Red/Black builds
then you can opt for the board
MSI Dragon Army over Asus ROG
price of the GTX970 SLi will be high
suggest going for single GTX980 or the MSI 290X Lightning
https://linustechtips.com/topic/272350-need-help-with-new-build/#findComment-3695440
